12-21-2016 09:45 PM
182 12345 ...
tools
  1. MJProtector's Avatar
    Hello,
    What about the Alien films?
    I brought one today but i'm not sure if it's good or not.
    04-02-2016 03:42 PM
  2. Waipio11's Avatar
    Any problems of it peeling up with cases?
    I've had my zagg on for 3 days and it is already peeling up on the corners where it meets the case. Returning it.
    04-02-2016 03:49 PM
  3. PJRed2008's Avatar
    That's not a problem with the shield, they are made to fit the screen, not the dozens of cases that may or may not be used.
    04-02-2016 04:54 PM
  4. Waipio11's Avatar
    I understand that and normally would not even think about returning it. However I bought the shield and the case at the same time from Verizon, paid too much for both of them, and had them install them and the rep told me that it would not do exactly what it is doing. Thus I will return it.
    04-02-2016 05:14 PM
  5. Abby Normal's Avatar
    Im having problems with my Droid Maxx uncomanded reboots...... this is the second Moto phone that has done this to me........
    I think I'm going to get a S7E, probably this week....... anything new on the Zagg glass ????
    I hate to get this and go unprotected....
    I see where some of you are going with the Zagg HD DRY... how is that working out for you?
    05-18-2016 05:08 PM
  6. mdkappy's Avatar
    Picked up the Zagg tempered glass today at a Zagg kiosk in a local mall. It's outstanding! Only downside is that it has black across the top and bottom. Fits perfectly and looks great. They're coming out with more colors soon - gold for sure. Also picked up the Spigen Thin fit case - works perfectly. No gapping. Glass screen protector is secure - not coming up. Highly recommend. Had the HD protector and disliked it.
    05-18-2016 09:08 PM
  7. Bag of Leaves's Avatar
    Can you post some photos of the glass protector? Are they going to have a clear one (no dumb colors on the top and bottom)?
    05-18-2016 10:05 PM
  8. clintw22's Avatar
    Can you use a case also with the Zagg glass?
    05-19-2016 06:35 AM
  9. felloffthetruck's Avatar
    Zagg glass for the edge doesn't even exist.
    05-19-2016 10:03 AM
  10. bsteppuhn's Avatar
    I thought so too. Curious can you take a picture of the packaging
    05-19-2016 09:36 PM
  11. mdkappy's Avatar
    See attached.
    05-19-2016 10:06 PM
  12. bsteppuhn's Avatar
    See attached.
    Ooooooo how much!!
    05-19-2016 11:50 PM
  13. wrich2005's Avatar
    I have a tech armor one and it's pretty decent
    05-20-2016 01:33 AM
  14. mdkappy's Avatar
    It was $65, but if you bought any of their other screen protectors, they will give you a credit. I got a $25 credit for the HD protector. They take it and send it back to Zagg.
    Bag of Leaves likes this.
    05-20-2016 11:33 AM
  15. PJRed2008's Avatar
    According to Zagg's website the glass isn't available yet. Wonder if this is a 'beta' version to get responses?
    05-20-2016 12:09 PM
  16. louzer's Avatar
    I just called a Zagg kiosk at a mall not too far from me. He said that they just got the tempered glass protectors in a couple of days ago.
    He had no information about how it actually fits with a case. But he said I could come by and give one a try (he hasn't installed any yet).
    If you bought an HD screen protector, you have to do your return and Exchange through them. The kiosks are independent franchises. He told me that it costs 50.00 but would discount 5.00 if he's replacing an existing Zagg product.
    Posted via the Android Central App on the edge
    05-20-2016 01:29 PM
  17. bsteppuhn's Avatar
    Meanwhile in bfe Iowa guess I'll just have to wait til it officially comes out
    05-20-2016 10:41 PM
  18. bsteppuhn's Avatar
    This is glass or film?
    05-20-2016 10:41 PM
  19. msavic6's Avatar
    Are you in Canada? If so what kiosk did you purchase it from?
    05-21-2016 03:54 AM
  20. clintw22's Avatar
    Haha exactly what I was thinking. Lol
    05-21-2016 12:21 PM
  21. bsteppuhn's Avatar
    Lmao!
    05-21-2016 02:28 PM
  22. wrich2005's Avatar
    Its either a hard plastic or glass. Not sure. I have it on now the only bad part is that its not that strong so I'm assuming plastic, and it also interferes with using a case
    05-21-2016 07:30 PM
  23. mdkappy's Avatar
    I'm in New Jersey. I purchased it at a Zagg kiosk in a local mall. It is glass. Nice and smooth like their other glass protector for the S7 (non-edge). Very satisfied so far.
    05-21-2016 11:46 PM
  24. clintw22's Avatar
    Do you use a case with it?
    05-22-2016 12:12 AM
  25. louzer's Avatar
    ^^This. If so, what case? And does it stay in place with a case on?
    05-22-2016 12:24 AM
182 12345 ...
  1. How much bloatware is on the S7?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-08-2016, 09:49 AM
  2. S7 - Fast Charger for $39.99
    By ihtc in forum Samsung Galaxy S7
    Last Post: 02-23-2016, 10:58 PM
  3. Replies: 1
    Last Post: 02-23-2016, 01:35 PM
  4. disable lock screen access to status bar, camera and phone
    By fryingfish in forum Ask a Question
    Last Post: 02-23-2016, 12:52 PM
  5. How much bloatware is on the S7?
    Last Post: 02-23-2016, 12:39 PM
