12-21-2016 08:45 PM
182 ... 678
tools
  1. bradfieldj1's Avatar
    Would you mind posting a link to the zagg glass that you are using? I am having trouble finding it.
    Thank you,
    Jamison
    11-30-2016 08:19 AM
  2. mxrider821's Avatar
    Thank you,
    Jamison
    The new one Zagg is developing is not out yet.. They had to recall all of the old ones for the S7 edge and figure out the problem of why it wasn't sticking to the screen. Just be patient, it should be out within the next month or 2 hopefully. Sucks but what are you gonna do, right?
    I just went with the dry HD from zagg for now with the S7 Edge while I wait for the for the Zagg glass too. It's definitely Better than nothing, Hope this helps
    11-30-2016 11:35 AM
  3. jonty12's Avatar
    I gave up after the 5th broken protector. Four worked to protect the screen, the 5th didn't. Screen break matched "protector" break. I figure I'm spending $10+ on each one, I'm up to about $55 and have a broken actual screen. Going to go naked.
    11-30-2016 07:37 PM
  4. mary beth hale's Avatar
    Just got the Gpel Gen 2 TGSP after trying the original and removing it after 1 day. The Gen 2 is so much better. Perfectly clear. No haze, rainbow, glitter effect or dot matrix look. No clicking noise on any of the edges. Typing is effortless. Using it with the Gpel case and no lifting at all. Going to try it with my favorite Incipio Dualpro but I'm thinking that will be a fail. We'll see... Anyway, the Gen 2 is far superior to the original.
    MoshuXXL likes this.
    12-06-2016 09:13 PM
  5. underway99's Avatar
    I tried and returned the gen 2 TGSP from GPEL. It was clear and fit really well on the edges, but it didn't fit very well over the BACK button. It effectively left a dead spot where I had to press really hard to make the touch register. That was without a case. I also tried it with the Supcase Unicorn Beetle Pro that many have recommended as good with this TGSP. No change. I really liked that combination, and it seemed to fit a lot better than the gen 1 TGSP did with my Otterbox Commuter. Looks like I'll stick with the Zagg HD Clear and wait for the redesigned Zagg TGSP. Maybe the third one will work?
    JimA and mary beth hale like this.
    12-06-2016 10:22 PM
  6. Air Planet's Avatar
    True. I had the Spigen version (can't remember what they call it) and it applied perfectly; no issue with the edges. I eventually took it off (like phone better without it) but the product works as advertised.
    Have you tried spigen crystal shell or ringke fusion clear ?
    12-17-2016 06:03 PM
  7. henrykrinkle's Avatar
    This is the one I had: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    12-21-2016 08:45 PM
182 ... 678
  1. How much bloatware is on the S7?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-08-2016, 08:49 AM
  2. S7 - Fast Charger for $39.99
    By ihtc in forum Samsung Galaxy S7
    Last Post: 02-23-2016, 09:58 PM
  3. Replies: 1
    Last Post: 02-23-2016, 12:35 PM
  4. disable lock screen access to status bar, camera and phone
    By fryingfish in forum Ask a Question
    Last Post: 02-23-2016, 11:52 AM
  5. How much bloatware is on the S7?
    Last Post: 02-23-2016, 11:39 AM
