atzau
not sure but i believe it's to hide the glue.Why do most of the glass screen protectors have a colored top and bottom section? It looks like Zagg has this too. Why not have the whole thing clear?
Just purchased this. I'll report back once i receive.
Clear Glass Screen Protector for Samsung Galaxy S7 Edge | Case-Mate – Case-Mate.com
Do you use a case with it?
This is my next question. But think of it this way Clint, by the time it makes it to us the flaws will be out
Here is a pic with the zag glass for the S7 Edge with the Unicorn Beetle case.
So far it looks great. No problems for the last two days.
Very pleased.View attachment 228269
Any issues with any gaps between the protector and screen glass itself?I have had no problems so far.. Like I said it has only been 2 days with case on.
No issues at the moment. I ran my thumb over the entire screen did not feel any gaps or heard popping noisesAny issues with any gaps between the protector and screen glass itself?
I do not use the holster, but I just put the phone into the holster both ways to determine if there would be a problem. As far as I can tell there are no problems when using the holster when snapping in the phone either way (facing front/facing Back).Any issues using the holster?
Posted via the Android Central App on the edge
I'm wondering is that a screen shot or a picture taken off the web site? If so, why is it tilted? Top and bottom are straight, just not the screen. I guess it had to be a picture right?
I was at Walmart today and I saw that their proglass glass protectors had one for the S7 Edge. It's $20 and the color was silver. I wasn't sure about it since I wanted to see reviews, but I couldn't find any online.
This looks like the one I bought (see above post). It cracked when I put it on and noticed it was plastic not glass. Let us know your experience.
Justin
I just bought the proglass at walmart. The glue is around the edges. When I tried it with my symmetry case, the protector buckled in the middle. I'll keep searching.
