1. cnotes2019's Avatar
    I want the edge so badly! But I don't want to use my basic line on my att line. I would rather use an eligible udp line on my att or Verizon line. Which would be the safest route to upgrade?
    02-23-2016 07:26 PM
  2. dpham00's Avatar
    Both att and Verizon allows udp to upgrade on dpp/next and keep udp .
    02-23-2016 07:30 PM
  3. cnotes2019's Avatar
    Good to know. Thanks
    02-24-2016 05:22 AM
  4. cnotes2019's Avatar
    Can you do dpp via Best Buy?
    02-24-2016 05:23 AM
  5. dpham00's Avatar
    I see the dpp option on best buy
    S7 Edge - better chance of keeping udp? Upgrade on Verizon or AT&T?-uploadfromtaptalk1456342724579.jpg
    02-24-2016 01:38 PM
  1. S7 vs. S7 Edge - which is better for GearVR?
    By KillerQ in forum Samsung Galaxy S7 edge
    Last Post: 02-29-2016, 05:21 PM
  2. Replies: 13
    Last Post: 02-26-2016, 07:04 AM
  3. How do i upgrade from android OS 4.2.2
    Last Post: 02-24-2016, 04:19 AM
  4. Replies: 1
  5. Replies: 0
    Last Post: 02-23-2016, 07:14 PM
