Here is a great tool for camera comparisons.
Photo Compare Tool - GSMArena.com
You select at least two cameras and then compare the colors, contrast, etc. between the two samples. I like moving the magnifying area around and looking at the color squares on the ISO 12233 poster, then I click on the good light poster and move the magnifying area around on there. Take a look at the tips of the paint brushes, the Lincoln $5 bill, and then pay close attention to the London bus route map (above the paint brush handles). Look at it again at these same areas in the low light poster. You can really separate the good cameras from the lousy ones.
For your third camera comparison, pick out the Microsoft Lumina 950XL. Probably the best phone camera in the bunch.
Older phones can be compared on the ISO 12233 chart and the color poster (old) chart.
