1. nonie's Avatar
    Anyone checked how to turn data on and off.
    I have s5 Att and have to go through several steps to get to where to turn on
    Posted from Android Central
    02-26-2016 01:44 PM
  2. dpham00's Avatar
    This is specific to certain variants of the s5 and s6. It wouldn't surprise me if att does it again here.
    You can probably add it back using the quickpanel Manager from the play store, I believe that that worked for the s6/note 5.
    02-26-2016 01:45 PM
  3. nonie's Avatar
    I hope not.
    I couldn't add it on s5.
    02-26-2016 01:53 PM
  4. dpham00's Avatar
    I hope not.
    If you can't add it then you can use a third party widget in the notification panel. Certainly not as clean as a stock toggle, but hey... Would save you a few steps.
    nonie likes this.
    02-26-2016 02:04 PM
  5. nonie's Avatar
    I did that but one of the updates wouldn't let it work anymore. ,
    02-26-2016 02:12 PM
  6. Bearcats98's Avatar
    So I can't imagine Samsung is "blocking" turning off data. However I visited Best Buy to play with it...and couldn't find it. I toggle my data on an off a lot especially when I am out of the country. Making it a chore would not be pleasant.
    02-27-2016 12:27 PM
  7. nonie's Avatar
    I haven't seen one in person. I wouldn't think they would block turning it off, but the way my s5 is, takes a bit to turn data on and off.
    02-27-2016 12:32 PM
  8. Bearcats98's Avatar
    My brother has S5 and he has to go to settings, Data and uncheck Mobile Data and Limit Mobile Data.
    I showed him my really old phone (Droid DNA) and showed him the widget....lol HTC Sense versus Samsung TW perhaps?
    02-27-2016 12:35 PM
  1. Data recovery
    Last Post: 03-11-2016, 03:00 AM
  2. Replies: 2
    Last Post: 03-03-2016, 07:52 AM
  3. My S2 used up all of my data!
    By Thebiggestsamsungfan in forum Samsung Gear S2
    Last Post: 02-29-2016, 11:19 AM
  4. all my data deleted
    Last Post: 02-26-2016, 10:59 AM
  5. Mobile Data Turning On Event it was Off
    Last Post: 02-26-2016, 09:44 AM
