10-21-2017 04:22 AM
694 ... 2425262728
tools
  1. drusum's Avatar
    S8 System dump most of them work on S7 Edge, just install like normal app
    Root?
    04-04-2017 09:53 AM
  2. Ruben Ocasio's Avatar
    Root?
    Nope I'm on AT&T S7 Edge no root!
    04-04-2017 09:56 AM
  3. LineKill's Avatar
    Still rocking that S8 look
    Nova Prime
    GS8 Icons
    Weather Widget is XWidgets
    S8 Wallpaper
    I cannot decide whether I like the Zooper or XWidget weather widget better.
    Right now I am using both until I can decide.
    Decisions, decisions...
    04-04-2017 09:57 AM
  4. LineKill's Avatar
    Nova Prime
    GS8 Icons
    S8 Wallpaper
    I have noticed that my XWidget weather is off about 8 degrees. Do you know if there is a way to change providers?
    04-04-2017 10:31 AM
  5. drusum's Avatar
    I like XWidgets more because it doesn't kill your battery as much as Zooper does. It uses about as much battery as the stock widgets. It's only ever off by a degree for me. It uses AccuWeather which is pretty close to accurate. I'm not really sure how to edit providers. I do know the auto location doesn't exactly work correctly and I just add my city and has no issues updating the weather.
    04-04-2017 10:36 AM
  6. drusum's Avatar
    I found the dump file on XDA. Thanks for posting about it or I would've never figured it out haha
    Ruben Ocasio likes this.
    04-04-2017 10:37 AM
  7. LineKill's Avatar
    Thank you, I appreciate all the info. I do have it on auto, so I will add my city and see if that helps.
    04-04-2017 10:40 AM
  8. drusum's Avatar
    It should. Also if you're interested in turning stock TouchWiz into the new S8 look let me know.
    LineKill likes this.
    04-04-2017 10:44 AM
  9. drusum's Avatar
    Does Rectangle and Oval work for you? Animated Gif works for me but freezes when I use the other two. What all did you install?
    04-04-2017 11:50 AM
  10. Ruben Ocasio's Avatar
    I just install that didn't try the other 2 maybe if you ask in XDA someone might know, also the AOD from S8 here's mines on S7 Edge
    04-04-2017 12:01 PM
  11. drusum's Avatar
    https://uploads.tapatalk-cdn.com/201...e15d02debb.jpg
    Do you have the S8 Launcher installed?
    04-04-2017 12:08 PM
  12. Ruben Ocasio's Avatar
    Yup have it no issues plus you can add the app draw icon on homescreen or hide it by pressing home screen and go to touchwiz settings! Plus weather and weather widget is S8 Plus as well!
    drusum likes this.
    04-04-2017 12:20 PM
  13. Ruben Ocasio's Avatar
    Also folder with S8 Plus touchwiz adds more apps in folder!
    drusum likes this.
    04-04-2017 12:23 PM
  14. drusum's Avatar
    I had it installed but reverted back to stock TouchWiz, I'm thinking I need the S8 Launcher for the Smart Select to work. Appreciate the help and loving the custom themes you make
    04-04-2017 12:26 PM
  15. Ruben Ocasio's Avatar
    Looks like your right just tested no freeze here at all, so it works with no issues!
    04-04-2017 12:36 PM
  16. drusum's Avatar
    I tried all that and still doesn't work for me. Oh well lol
    04-04-2017 01:34 PM
  17. Ruben Ocasio's Avatar
    The day getting closer for the S8 Plus that i pre-order should be in my hands by the 19 of April, got the Black S8 Plus!
    drusum likes this.
    04-04-2017 01:39 PM
  18. drusum's Avatar
    Nice
    Law2138 likes this.
    04-04-2017 01:49 PM
  19. Ruben Ocasio's Avatar
    Nice
    Here's my S7 Edge next to my S8 Plus case which the S7 Edge is using the same case i bought for S8 Plus Unicorn Beetle case, look at the size differences!
    drusum likes this.
    04-04-2017 02:01 PM
  20. Law2138's Avatar
    Screen shot of animation gif like Note 7 had to make animation gif on my S7 Edge
    How did you get it to launch? I've installed the apk, but didn't the Note 7 turn it on when the S-pen was removed?
    04-04-2017 03:00 PM
  21. drusum's Avatar
    It's activated through the edge panel
    toneofark likes this.
    04-04-2017 06:53 PM
  22. drusum's Avatar
    https://uploads.tapatalk-cdn.com/201...5a4b8952fb.jpghttps://uploads.tapatalk-cdn.com/201...2c07075859.jpghttps://uploads.tapatalk-cdn.com/201...5029d08bc6.jpg
    I really want one but I think I'm just gonna wait for the S9+ or the new Note. The new fingerprint scanner placement is too awkward for my liking.
    Ruben Ocasio and Law2138 like this.
    04-04-2017 08:11 PM
  23. toneofark's Avatar
    S8 Launcher and weather widget.
    drusum and Law2138 like this.
    04-05-2017 11:13 PM
  24. drusum's Avatar
    If you downloaded the new Themes apk there's an S8 theme on there. There's also a few apks released that work and have the new icons. Can find em all on xda or apkmirror
    04-06-2017 12:03 PM
  25. pjwk81's Avatar
    Current screen, now that the widget is working right.
    Attached Thumbnails Post homescreen screenshots taken on your Samsung S7 Edge!-homescreen.jpg
    drusum and toneofark like this.
    04-07-2017 02:57 AM
694 ... 2425262728
  1. Galaxy S6 Edge locked, how can I get back in?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 06-12-2016, 04:09 AM
  2. Led is not working for Easy screen in S6 Edge, how can I fix it?
    Last Post: 04-01-2016, 08:39 AM
  3. Replies: 0
    Last Post: 04-01-2016, 08:33 AM
  4. Can I record notes and meetings on my Samsung Galaxy S7?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 04-01-2016, 07:46 AM
