06-05-2016 02:17 PM
143 ... 3456
tools
  1. anon(5630457)'s Avatar
    Just applied the skinomi hd clear and already not too happy with it I have to wait about 4-5 hours for it to dry and am already tempted to get the HD Dry from Zagg until their curved comes out. Ugh.
    I installed my matte Skinomi protector before I went to bed so it'd dry overnight.
    Posted via the Android Central App on the S7 edge
    03-12-2016 06:33 PM
  2. Dena Ahmed's Avatar
    Yeah that's what I just did now so I can leave it to charge and dry as i sleep
    03-12-2016 06:35 PM
  3. KimJongOMG's Avatar
    Was the Zagg HD relatively easy to install? I guess that's what those two reviewers were complaining about...
    Super easy for me.
    03-12-2016 07:00 PM
  4. eRod v1.0's Avatar
    The xtreme shield protectors are not good. They feel so rubbery. They are making taps on my screen unresponsive or delayed. I'm looking at the iQ shield one now.
    03-12-2016 07:45 PM
  5. dman76's Avatar
    Super easy for me.
    Is the Zagg curved too, or does it come flat?
    03-12-2016 07:53 PM
  6. dryja123's Avatar
    Curved, I wasn't successful with getting it to bond to the curves. The Skinomi stuck no problem.
    03-12-2016 08:01 PM
  7. mountainman15's Avatar
    Purchased the Zagg HD from Best Buy today for my 7 edge. While I was making my purchase the guy told me that they do not accept returns on screen protectors once they've been opened.
    The Zagg was a pita to install because every time I would squeegee the screen it would shift. After reapplying it 3 times, wearing gloves, it looked like crap. I ended up just tossing it in the trash. Zagg wants $4 to ship their warranty replacement. I should have just lit $25 on fire.
    Earlier I used the Skinomi matte which went on flawless. I took it off because it made the screen pixelated. I ordered up the Skinomi HD clear hoping I'll have better luck.
    Wish I would have seen this before I bought the Zagg - complete garbage especially considering it was $25. Even after it settled and some of the micro bubbles went away, it totally has that orange peel look to it. And $4 for a warranty replacement is a joke. Stay away from the Zagg HD.
    SR45 likes this.
    03-12-2016 08:03 PM
  8. Yorkshire_Bourne's Avatar
    I've just spent £30 on a Tech21 Evo case for my S7.
    I also have a full screen protector but unfortunately the edges don't like the new case, so other than the central area of the screen, the edges are all raised away from the phone screen.
    Is this likely to happen with a more expensive full size tempered glass protector?
    I've never had one before, but I don't want to spend anymore money until I can figure out whether it's the case thats at fault or its the cheap screen protector not sticking properly?!?!?!
    03-15-2016 07:06 AM
  9. pst23's Avatar
    I have given up trying to find a great screen protector or the perfect screen protector install. the closest I've been able to get to perfect is t-mobile's pure gear screen protector and it doesn't even cover the entire edge.
    03-15-2016 08:00 AM
  10. jneusch's Avatar
    Screen protectors take away from the beauty of the actual screen
    Don't disagree, however scratches can affect resale value. They are not for everyone.
    03-15-2016 08:30 AM
  11. Jdt0109's Avatar
    Anyone using any? If so what?
    03-15-2016 11:52 AM
  12. msnider23's Avatar
    I'm using the zagg body wrap, front and back protection. It's not tempered glass, but it works nicely and has a good feel in the hand
    03-15-2016 11:57 AM
  13. jredfearn390's Avatar
    Zagg HD Full Body..I'm waiting for the intial cost to drop before I try Tempered . I have the Zagg and I gotta say after the first couple if days it seems to really disappear at first when it was settling I was worried but after a couple of days it layed down and I can't tell....One thing watch the corners especially when removing and replacing your cases I noticed it started to push up the corners for the first couple of days but seems to be getting better
    03-15-2016 12:03 PM
  14. jfoofoo's Avatar
    The Skinomi Matte protector saved my phone from going back because the damn thing attracted so much oil. I love the way it looks, it looks like sheet metal instead of a mirror.
    It was a super easy wet install and it perfectly fits the phone. No problems with it not adhering.
    I got one of those, 5 days later I had to peel it off. It has that grainy effect on the screen. However the fit and feel were perfect.
    03-17-2016 08:08 PM
  15. dryja123's Avatar
    I had to do the same thing. The pixelation never went away and the colors were too washed out. I purchased the Skinomi HD clear and love it.
    I was really disappointed because I loved the matte finish.
    03-17-2016 08:36 PM
  16. itsnotmeitsyou's Avatar
    I have Tmobile Jump on demand and I like the feel of the naked screen too much to cover it up for the 3-4 months I'll keep the phone.
    03-17-2016 10:46 PM
  17. jneusch's Avatar
    I installed the Zagg HD dry yesterday. Super easy to install with no issues. I'm a huge fan of Zagg and love their lifetime warranty program. The edges are sticking just fine. I used my thumbs per the instructions.
    03-17-2016 11:44 PM
  18. dpham00's Avatar
    Don't forget the $5.99 Shipping and handling charge for replacements
    03-18-2016 12:17 AM
  19. dryja123's Avatar
    You're correct. I made the mistake of purchasing a Zagg protector and I should have known better when Best Buy told me no returns at the point of purchase.
    I had the hardest time getting the protector to adhere to the curve of the screen. Since I peeled the screen back so many times to reapply the solution it stretched out. I went online, registered my purchase, and was going to file a claim for a replacement when I saw I had to pay return shipping along with shipping for a new protector.
    Tossed thd Zagg in the trash where it belonged.
    johnriii likes this.
    03-18-2016 09:09 AM
  20. sangs's Avatar
    Very pleased with my ArmorSuit MilitaryShield protector. Edge to edge coverage, adhered nicely (wet application) and works perfectly. Screen still looks brilliant, doesn't attract too much oil, holes lined up perfectly. Good $8 investment. http://www.amazon.com/gp/product/B01...cUvbUpU5069248
    03-18-2016 09:21 AM
  21. cchou168's Avatar
    If you get one of those wet installation. Make sure you do it "in the water". I did it. Perfect. No dirt nothing underneath. Wash it and do it again if any needed.
    03-18-2016 09:21 PM
  22. MrOnager's Avatar
    Hi all. (Lucky) new guy here. Got my Verizon gold S7E early & my Spigen Neo Hybird case from Amazon before they ran out. My tempered glass screen protector got here today. Paid $20, but I see they're now $25. It's made by Cooyee & sold by dz-tech. It's my 1st ever protector, but I'm impressed. Came very well packaged, pretty decent instructions in English, alcohol pad, cleaning rag & something called a dust sticker. All the holes match up, it meets the edge of the case perfectly, the curved edges stick & you can barely tell it's there. It does take away from some of the screen sensitivity, but I'd guess that the way with all of them. No problem with fingerprint ID on the home button or the back button. Sorry I'm too new to post links or pics
    03-18-2016 10:39 PM
  23. atzau's Avatar
    How does the case fit with the screen protector on? Any interference? I've got the spigen tough armour case and I'm desperately looking for a good screen protector...
    03-22-2016 11:12 PM
  24. echo_808's Avatar
    I'm getting cover lift thanks to my neo hybrid case. Wish Zagg made it a tiny bit smaller so it doesn't get into a fight with the case.
    Dang. I also have the Spigen Neo Hybrid case. Seeing that the Zagg Glass Contour is edge to edge, i see that it'll have the same issue...hopefully not though.
    03-23-2016 12:18 AM
  25. MrOnager's Avatar
    The two mate perfectly. Once you install the screen protector, you can take the case on/off with no problem. Gotta be careful as the SP states it's a one time only installation & I'll take teir word for it. After using it for a while, I wish there was a happy medium in screen sensitivity between the bare screen & with the protector on. It sometimes takes a good tap to register. I'm still happy & not going to do a lot of experimenting at two bits a pop for glass. As it's my first, I really wonder if glass is worth the price difference? Thoughts?
    03-23-2016 12:27 AM
143 ... 3456
  1. Galaxy S7 - Way to keep lighted buttons at bottom on longer?
    By dhinged in forum Samsung Galaxy S7
    Last Post: 04-22-2016, 03:57 PM
  2. Samsung S5 and Smart samsung TV screen mirroring
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-01-2016, 12:11 PM
  3. Why is the audio playback delayed or sounds in slow motion? S6 edge+
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 02-28-2016, 10:08 PM
  4. How can I get the photos off of my Galaxy Note 3?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 02-28-2016, 11:34 AM
  5. Replies: 4
    Last Post: 02-28-2016, 10:35 AM
