06-05-2016 01:17 PM
143 ... 456
tools
  1. felloffthetruck's Avatar
    I have the Bodyguardz HD curved on mine and it's been working perfect.
    It's cut shorter then the Zagg so it works with every case I've tried so far.
    03-23-2016 09:28 AM
  2. mastinoblu's Avatar
    Hi.
    I just bought one from x-skinz - The best shield protector , money can buy !
    A friend told me about them and also he gave me a coupon code for 10%.
    I allready get it and it is amazing. It is like zagg but much better quality of the film and cover the entire display perfectly.
    And at 5.50 $..... it is more than a bargain .
    For whom it is interested the code is skinz10 . Hope it still works.
    Cheers.
    03-28-2016 10:50 AM
  3. Swiftfury's Avatar
    Hi.
    Cheers.
    Anyone try this? Don't see any reviews around and this guy seems shady with his "bargains" and "coupon codes".
    04-14-2016 09:41 AM
  4. Srambo217's Avatar
    Got my Edge today. Put a wet screen protector from PhantomSkinz on it. I primarily use their products on all my device, you can find 90%+ off coupons on sites like retailmenot and they offer free shipping on all orders. Think I spent $1.99 for 2 shipped and had 0 issues applying it.
    05-09-2016 11:58 PM
  5. arab305's Avatar
    I got an email today from Zang saying they are releasing the tempered glass protector. Any one planning on purchasing? My Zagg HD is coming up on the edges and it really is annoying
    05-27-2016 09:06 AM
  6. Cordt Hanson's Avatar
    They are garbage. Literally identical to one you can get on eBay for 20$.
    They feel like plastic and have an insane amount of flex. I actually removed mine and bent it to a full U shape before it shattered.
    They only adhere to the top and bottom edge and the entire thing does not actually make full contact with the screen so the feel is incredibly cheap and awful. Stick with gel type protectors.
    The way to make the gel type ones stick to the edges and not peel is to make sure they dry for as long as possible and do not put them in and out of your pocket without a case of some kind. Flip cover is the best way to keep your screen protector from peeling.. (and coincidentally the screen protector is the best way to keep your flip cover from scratching the hell out of your screen)
    05-27-2016 09:20 AM
  7. Thompsontriplets's Avatar
    I also had the Zagg Hd on mine and now switched to the Zagg Glass. It has been on for almost a week now with no problems. They put it on at the Zagg place so I couldnt tell if the glue is every where or just on the sides. With the case Im using there is no problems with typing or clicking noise or lifting etc.. It as been good so far
    Attached Thumbnails Galaxy S7 Edge - What screen protector ?-attach764_20160522_135448.jpg
    05-27-2016 10:34 PM
  8. Jayjit Biswas's Avatar
    No for S7 edge no screen protector or tampered glass works with a case. I put IQ Shield mate but it came out when I wanted to spigen back cover. Same happened with tampered glass. My 2K INR lost in vein. Now I am using Caselogy cover without screen protector.
    05-28-2016 02:08 PM
  9. ThrottleJohnny's Avatar
    Still looking for a protector that doesn't dull the vibrant colors of the screen.
    05-28-2016 03:24 PM
  10. dluiiulb's Avatar
    Has anyone tried the iShieldz HD Screen Protector for their S7 edge?
    currently i have a commuter otterbox case with a puretek roll on screen protector. the case is fantastic, really really do not like the screen protector. it is rubbery, and the sides peeled up immediately after installing.
    06-02-2016 05:58 PM
  11. chanchan05's Avatar
    Has anyone tried one of those liquid armor/Kristall screen protectors?
    06-02-2016 07:38 PM
  12. BillPhillips's Avatar
    I just installed two IQ Shield skins on the S7 Edge, one on my new phone and one on my son's. Got them delivered in one day (free shipping) on Amazon, and installed them on 2 day old phones. I watched the IQ Shield installation video (twice) on YouTube, and followed their instructions precisely. Installed mine first, and got a minor bubble or two under the skin, but then installed my son's perfectly. Seems to be fine, though I notice that I have to tap a little harder when sending a text message. My son installed a fingerprint password access to his phone and he said that worked fine with the IQ Shield.
    06-03-2016 04:37 AM
  13. sangs's Avatar
    My Zagg HD screen protector works perfectly fine with all my cases - including the Samsung OEM leather snap back case. So not sure how you can make such a definitive statement about screen protectors not working with a case.
    06-03-2016 08:05 AM
  14. dryja123's Avatar
    What about the case friendly Skinomi SP? I've had it on my phone with the Spigen tough armor and it works perfect.
    06-03-2016 12:18 PM
  15. anon(19981)'s Avatar
    Has anyone tried Liquid Armour from Staples on this or any other phone before? I watched an older YouTube video of it getting scratched but the reviewer was able to scratch the coating off. I would love for something like this to really work.
    06-04-2016 06:48 PM
  16. BuffEWO's Avatar
    I to like the Armor Suit but....when I put my case on several of the edges at the top and bottom of the screen came up. Sides are fine. Have you had a problem like that with any case you use? If not, what are you using for a case? My case is a Spigen with the kick-stand
    06-04-2016 08:25 PM
  17. dryja123's Avatar
    Skinomi makes a screen friendly protector. It's an exact fit for using a case. I would say there's less than 1 mm separation from the edge of the Skinomi to the edge of the Spigen Tough Armor.
    You can pick up a 2 pack for $8 on amazon.
    06-05-2016 11:03 AM
  18. BuffEWO's Avatar
    Thanks!
    06-05-2016 01:17 PM
143 ... 456
  1. Galaxy S7 - Way to keep lighted buttons at bottom on longer?
    By dhinged in forum Samsung Galaxy S7
    Last Post: 04-22-2016, 02:57 PM
  2. Samsung S5 and Smart samsung TV screen mirroring
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-01-2016, 11:11 AM
  3. Why is the audio playback delayed or sounds in slow motion? S6 edge+
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 02-28-2016, 09:08 PM
  4. How can I get the photos off of my Galaxy Note 3?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 02-28-2016, 10:34 AM
  5. Replies: 4
    Last Post: 02-28-2016, 09:35 AM
