onthecouchagain
Does the "volume warning" pop up a lot like it does on the current generation Galaxies? They're so annoying.
Yes there still is the high volume warningDoes the "volume warning" pop up a lot like it does on the current generation Galaxies? They're so annoying.
Seems to be missing here too.Do you mind checking if Android Multi user is back?
Feels great in the hand. The screen is nice and the size is great. Definately not big. I was expecting this to be much biggerHow does it feel in the hand does it feel like a phablet or a midsized phone? Did you try it with the vr gear how is the quality and are the edges noticeable when playing?
Tried to do a little comparison on the FP scanners:
S7edge is better but not much. But I think it recognizes my fingers better than the S6.
Also tried to do a slowmo video but for some reason when uploaded to youtube it removes the slowmo from it (Anyone know why?)
Can't judge yet as my home has a totally ****ty mobile reception (max 2 bars) so it screws the testing a little.What are your impressions on battery life so far?
This is why I still like my Note Edge. I'm not so sure I want to order a S7 Edge now. I was thinking of ordering one today but I may continue to wait a while.The edge isn't used for notifications. And it seems neither is the AoS. Or maybe it's used only for samsungs own apps
