No ir blasterhi, I really like to know if you can use the s7 as an infrared transmitter/ called the infrared blaster (like the s6 edge does)
According to samsung's dutch support it does(confirmed twice). They do agree its not visible on the top side of the device.
Can you check if you can remote control your tv set (by infrared) or use a camera to detect infrared signals (with some app)?
Lots of ppl want to know, including me
Thanks!!!
