1. SROJR's Avatar
    I'll be coming from an S5 where only a limited number of cases worked with wireless charging. I had found a Diztronic (sp?) that worked great but it seemed to be one of the few that worked with the wireless charging back. Is there the same kind of limitation with the S7 Edge? I'm assuming the wireless charging capability is built into the phone as I've not seen anything about the wireless charging needing any special. Will any case work?
    02-27-2016 10:46 AM
  2. dpham00's Avatar
    It is built into the phone. And most thinner cases should work . but some thick back cases might not work, or metal cases.
    02-27-2016 10:50 AM
  3. felloffthetruck's Avatar
    I have used wireless charging with cases a thick as the Otterbox defender and all worked fine. This was Note 5, Galaxy S6 I'm taking about.
    02-27-2016 11:27 AM
  1. Replies: 1
    Last Post: 03-31-2016, 02:12 PM
  2. Replies: 35
    Last Post: 03-05-2016, 04:54 PM
  3. Carbon fiber Galaxy S7 Edge case?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 02-27-2016, 09:56 AM
  4. Why isn't my battery charging even when plugged in?
    By AC Question in forum Hardware Hideaway
    Last Post: 02-27-2016, 09:39 AM
  5. Replies: 0
    Last Post: 02-27-2016, 09:01 AM
