1. TMavC5's Avatar
    Just want to make sure if anyone know if the newest S7/S7E is QI or PMA for AT&T?
    02-27-2016 09:16 PM
  2. Storm24's Avatar
    It is actually both. You can use either standard with the S7/S7E. It was that way with the S6
    dpham00 likes this.
    02-27-2016 09:20 PM
  3. TMavC5's Avatar
    Awesome!!! And thanks!!!
    Storm24 likes this.
    02-27-2016 09:31 PM
  4. dpham00's Avatar
    Yeah the s6 worked with both. This should be the same
    TMavC5 likes this.
    02-27-2016 10:07 PM
  5. RadiantDuck's Avatar
    Is there any real advantage to either one?
    02-28-2016 12:49 AM
  6. gmtom1's Avatar
    I had both for my s6 and found the qi to be more reliable than PMA. The PMA was way more finicky about placement and it would always disconnect.
    02-28-2016 08:58 AM
  7. dpham00's Avatar
    Qi seems to be more widespread
    02-28-2016 09:42 AM
  8. TMavC5's Avatar
    Yes, QI by far better and PMA sucks because sometime it won't charge when you think its charging. Hate it!
    02-28-2016 11:17 AM
  9. RadiantDuck's Avatar
    Good to know! Thanks!
    02-28-2016 11:23 AM
  1. Galaxy S7 - Way to keep lighted buttons at bottom on longer?
    By dhinged in forum Samsung Galaxy S7
    Last Post: 04-22-2016, 02:57 PM
  2. Replies: 3
    Last Post: 03-22-2016, 07:18 PM
  3. Why is the audio playback delayed or sounds in slow motion? S6 edge+
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 02-28-2016, 09:08 PM
  4. How can I get the photos off of my Galaxy Note 3?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 02-28-2016, 10:34 AM
  5. S7 Curve design
    By mango1228 in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2016, 08:51 AM
