1. PsychDoc's Avatar
    I downloaded Samsung's Smart Switch and that seems like it would do everything without a hitch but I've read elsewhere that Helium is the preferred method of doing this. Is there any difference between these two apps and, if so, is there one you would recommend over the other. If so, why?
    02-28-2016 03:43 PM
  2. anon(5630457)'s Avatar
    Literally everything gets transferred over with Samsung Smart Switch. You'll get all your apps, contacts, music, pictures--everything--on your new phone. It'll just take awhile.
    02-28-2016 04:12 PM
  3. Storm24's Avatar
    I wonder if there is a setting as to where you can restore what you want to where you want. For instance, I would like for my apps to go on my internal SD Card. But my music and videos I would want on my external SD card.
    02-28-2016 06:52 PM
  4. anon(5630457)'s Avatar
    I'm not sure. When I used Samsung Smart Switch, it was between a Note 5 and an S6 active.
    02-28-2016 08:06 PM
  1. How do I quit Pandora on my Samsung Galaxy?
    By AC Question in forum Android Apps
    Last Post: 05-31-2016, 04:07 PM
  2. How do I delete from the Samsung or Android Music Player app?
    Last Post: 02-28-2016, 06:36 PM
  3. Replies: 1
    Last Post: 02-28-2016, 06:27 PM
  4. Can you retrieve pictures from deleted messages?
    Last Post: 02-28-2016, 02:44 PM
  5. How do you stop the sound when you swipe the screen to use the phone?
    Last Post: 02-28-2016, 02:34 PM
