1. PsychDoc's Avatar
    I know this is probably silly but are they the same ratio (as in 16:9 or 16:10)? I ask because the S7 Edge seems considerably smaller than the comparable sized Note screen. Hardly seems any bigger than the S6 screen.
    02-29-2016 05:11 PM
  2. SpookDroid's Avatar
    It is the same ratio. As a matter of fact, they have the same resolution, just different pixel density because the S7 Edge has a slightly smaller screen. The curvature might trick you into thinking it looks different, though.
    02-29-2016 05:33 PM
  1. Galaxy S7 Edge FULL User Manuals
    By ironass in forum Samsung Galaxy S7 edge
    Last Post: 08-21-2016, 08:37 AM
  2. Replies: 3
    Last Post: 03-16-2016, 12:22 PM
  3. Galaxy S7 FULL User Manuals
    Last Post: 03-01-2016, 03:26 AM
  4. Replies: 1
    Last Post: 02-29-2016, 05:48 PM
