1. vamsiguduru's Avatar
    hi , just pre-ordered samsung galaxy s7 edge black . cant wait to get hands on . i am iphone user for long time , thought its time for the change .i used to have nexus 7 long back for a couple of months but not so familiar. so how would be the transition and all?
    are there any apps to port everything from IOS to anroid.?
    thanks
    Tatt2014 likes this.
    02-29-2016 08:48 PM
  2. zainsikander32's Avatar
    Yes you can use Smart Switch by Samsung. It'll transfer everything. Welcome to the family! I hope you can convince others around you to make the switch too.
    02-29-2016 08:53 PM
  3. Golfdriver97's Avatar
    Welcome to the forums. You can also check this out: Switch to Android
    03-01-2016 08:33 AM
  4. Javier P's Avatar
    Welcome to the forums!
    03-01-2016 08:37 AM
  5. VW Maverick's Avatar
    Welcome to Android Central and Mobile Nations.
    Mav.
    03-01-2016 08:37 AM
  6. belodion's Avatar
    Hello and welcome to Android territory!🙋
    03-01-2016 08:45 AM
  7. itguyjax8430's Avatar
    thanks
    Welcome to Android Central!
    03-01-2016 09:03 AM
  8. sydneycooper1979's Avatar
    Hello! Welcome to Android Central!
    03-01-2016 10:45 AM
  9. STARGATE's Avatar
    Hello and welcome to the forums at Android Central!
    There's always a learn curve, but if you give it a chance you'll have a great time with Android.
    03-02-2016 07:28 AM
  10. AlphaTango414's Avatar
    03-07-2016 04:29 AM
  11. the tall guy's Avatar
    Hey and welcome to Android Central
    03-11-2016 02:42 AM
  12. B. Diddy's Avatar
    Moved from Intros to the S7 edge forum, which I thought would be more helpful for the OP.
    03-18-2016 01:27 PM
  13. Lakes21's Avatar
    I too am an iPhone user since 1st gen iPhone. Ive made the switch to android for the very first time with the S7 edge and I must say that I am very happy with it. glad to be part of the android community!
    Bodrul, jimbo1mcm and Tatt2014 like this.
    03-18-2016 02:08 PM
  14. jimbo1mcm's Avatar
    I go back and forth between Apple and Android. I have the 7Edge now and it is a far superior phone to the Iphone 6S plus. You will really enjoy the 7.
    03-18-2016 02:12 PM
  15. yomny Martinez's Avatar
    I also was back and forth between Apple and Android but i think i finally found my happy place. The phone is great, fits nicely in the hands and the camera is just great. Get samsung smart switch on your apple and it should transfer everything except apps that are not compatible from Apple store to Play store. Enjoy.
    03-18-2016 03:16 PM
  16. racingvike's Avatar
    My 16 yo son switched from the iPhone to the S7 last week and says he is glad that he did. After hearing him talk about how much he liked it my wife may be switching as well.
    I can also confirm the transfer of data from iPhone to S7 using SmartSwitch was as easy and painless for his phone as it was for me going from the S5 to the S7 edge.
    03-18-2016 03:41 PM
  17. Ale Aguilar 62's Avatar
    Wow I think you just did a great upgrade. Try the app MobileTrans, to transfer all your iphone data to any OS (in case that you still need it). Maybe your first days using android where difficult, because all of the changes you see, but after that, you'll realize that you made the right decision, because you have most of the apps for free and also have a lot more variety. I hope that you enjoy your new S7, you can tell me later if it's a lot better than an iphone. Greetings!
    03-18-2016 06:37 PM
  18. xSIN1134x's Avatar
    The s7 comes with the adapter needed for the Smart Switch, so that may be the best route.
    03-18-2016 06:51 PM
  19. D-Recka23's Avatar
    Was in the same boat. Best decision ever man.
    03-18-2016 09:44 PM
  20. wxman2003's Avatar
    Smart switch is a total disaster for macs. It doesn't work at all with my 2011 imac. Luckily for contacts having everything connected to google works. iSyncr works for transferring music. I really enjoy the S7 Edge. But if all you do is use apps, text and play video and music, there really is not much difference. Sure, you can put widgets on your phone but if you look at many screen shot photos of the S7 edge, they look like an iPhone.
    http://forums.androidcentral.com/sam...n-s7-edge.html
    03-18-2016 11:59 PM
  21. tim3477's Avatar
    I jump between iOS and Android regularly. But switched to the S7 Edge and so far this phone is superb. Samsung have done an amazing job.
    03-19-2016 03:30 AM
  22. Gator352's Avatar
    It's all about customization. You can make it "yours" and like no one elses. With the iPhone, you can change the background and put apps in folders, that's about it.
    limitbreak09 likes this.
    03-19-2016 07:24 AM
  23. Truman82's Avatar
    Wondering about doing the same jump. Any idea when android will support fingerprint unlocking in 3dt party apps? For example at the moment my bank app accepts my fingerprint as a security password which is so useful. That is on iOS.
    Another thing got me worried was I have heard a lot of users complaining sd card problems with the s7 edge.
    03-20-2016 02:01 AM
  24. jimbo1mcm's Avatar
    Absolutely no problems with the SD card. If you buy a quality card like a Samsung Pro, etc, they work perfectly.
    Truman82 likes this.
    03-20-2016 04:08 AM
  25. sfla99's Avatar
    With Marshmallow you can use fingerprint for apps that have support, as an example my password keeper allows for fingerprint, website logins allow for it so I see no reason other than developer support being any issue for your bank
    03-20-2016 09:07 AM
  1. Where to find AOSP music player?
    By UrDroid in forum Android Apps
    Last Post: 03-04-2016, 04:08 PM
  2. How to find where battery leaks??
    By Owen Kim in forum Samsung Galaxy S6
    Last Post: 03-02-2016, 04:57 PM
  3. How can I use the Verizon unlocked Galaxy Note4 with Metro PCS sim?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 03-02-2016, 06:47 AM
  4. How do I change the screen to a dark theme vs the white?
    Last Post: 03-01-2016, 01:48 PM
  5. Replies: 10
    Last Post: 02-29-2016, 09:25 PM
