1. Redraider001's Avatar
    First impressions: Amazingly light and easy to handle in spite of 5.5 inch screen.
    More testing and hands on in progress .. Will be comparing audio to LG V10 soon.
    02-29-2016 10:54 PM
  2. anon(522296)'s Avatar
    Yeah really want to know about the sound, hoping it's as good as the v10!
    02-29-2016 10:58 PM
  3. SR45's Avatar
    Sound quality / FingerPrint reader / Smoothness / Battery / and of course Camera if you please
    03-01-2016 04:26 AM
  4. dpham00's Avatar
    Let us know how you like it
    03-01-2016 06:44 AM
  5. Redraider001's Avatar
    Initial impressions regarding audio:
    I am using V10 as comparison without the Hi-Fi DAC enabled, Poweramp rock eq and bose ear plugs, FLAC and 320kbps:
    While the audio on S7 edge is not bad, it's not comparable to the V10 even without the DAC enabled. On the V10, the audio sounds more natural, has more depth and retains its quality even at higher volumes. Some of the subtle notes that you hear on one ear piece or at the back of the head are clear on the V10 compared to S7 edge.
    Overall opinion: Audio quality not comparable to V10 (even without DAC). It's still sounds good if you are coming from older generation phones.
    03-01-2016 07:20 AM
  6. erasat's Avatar
    Did you complete the Adapt Sound setting? I don't have the S7 edge yet, but if they haven't removed the option it should be under Sounds Settings or the OEM Music Player settings.
    If it's there and you haven't set it, please do so, you won't regret it.
    03-01-2016 09:12 AM
  7. Redraider001's Avatar
    Thanks, did the adapt sound setting, improved quite a bit but still falls short of V10 slightly. But I am satisfied with the overall phone so sound quality is a non-issue.
    03-02-2016 08:04 AM
  8. felloffthetruck's Avatar
    How is the external speaker when on speakerphone?
    03-02-2016 08:11 AM
  1. Replies: 1
    Last Post: 03-01-2016, 01:32 PM
  2. Gmail doesn't work on Samsung Galaxy S3
    By hkwhelan in forum Samsung Galaxy S3
    Last Post: 03-01-2016, 01:29 PM
  3. Replies: 1
    Last Post: 03-01-2016, 01:27 PM
  4. Why can't I get back into my Galaxy S3 after a master reset?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 02-29-2016, 11:23 PM
  5. My Galaxy S5 won't allow me to turn on multi-screen, why?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 02-29-2016, 10:12 PM
