1. Kilroy672's Avatar
    I was trying to put my micro SD card into my new phone tonight. The tray seems awful flimsy. I went to slide the tray back in with both the card and sim in the tray and looked like it would not fit back in. I was afraid that the SD card was going to jam up and fall inside the phone. Anyone else have this issue? I don't want to have to do that again.
    02-29-2016 11:21 PM
  2. TMavC5's Avatar
    It should glide right in without force. If you're forcing it. You doing it wrong. Open up manual if you unsure.
    Laura Knotek likes this.
    02-29-2016 11:27 PM
  3. Kilroy672's Avatar
    I had no problem. But the SD card wanted to fall off the tray as I inserted the tray back in. It took a few try's. That's what I meant to say.
    02-29-2016 11:37 PM
  4. bhatech's Avatar
    Yeah the tray is very flimsy, instead of that flimsy material it should have been metal like the iPhone or other phones. Even I felt the same thing when I put in my SIM card and SD card.
    03-01-2016 01:14 AM
  5. dpham00's Avatar
    Wow that sucks. Hopefully no one gets stuck.
    03-01-2016 06:40 AM
  6. Kilroy672's Avatar
    Glad to know I was not the only one who had problems. Yeah they should have used metal or a heavier plastic.
    03-01-2016 08:00 AM
  7. Antony Guan's Avatar
    I was expecting the sim tray to be like the one found in the Iphone...I was wrong! if you guys have time go look at the post i created about my issue with the sim tray.
    03-17-2016 02:02 AM
  1. How can I use the Verizon unlocked Galaxy Note4 with Metro PCS sim?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 03-02-2016, 06:47 AM
  2. SGH-I337 unlock for Verizon sim
    By Rebel331 in forum AT&T Samsung Galaxy S4
    Last Post: 02-29-2016, 01:18 PM
  3. How do I access files on my sd card on my Droid Turbo 2?
    By AC Question in forum Motorola Droid Turbo 2
    Last Post: 02-29-2016, 01:02 PM
  4. Flash drives and card readers
    By Grabber5.0 in forum Nexus 5X Accessories
    Last Post: 02-29-2016, 12:26 PM
  5. Why is neither phone memory or SD storage showing?
    By AC Question in forum Memory (RAM)
    Last Post: 02-29-2016, 10:19 AM
