1. KBx315x's Avatar
    Has anyone been able to find them online for a decent price? All i've seen is ones that cost 30.00.
    03-01-2016 09:33 AM
  2. LeoRex's Avatar
    Well... availability right now is tricky. First, the S7 Edge is REALLY new... second, tempered glass protectors for edged screens are not all that common. They are hard to manufacture (if done CORRECTLY).
    I'd check Amazon... to be honest, they are usually always the go-to to find the least expensive source for anything. If you can't find a cheaper one there, you mist likely won't find one anywhere. Outside the US, Alidirect might be the best option, but I haven't used them.
    03-01-2016 09:42 AM
  3. zipro's Avatar
    Honestly: get a plastic one for the first two or three weeks and wait until it has become clear which ones are any good. Otherwise you'll be replacing them like dirty underwear and it'll cost you more. I did that with the EDGE+ - most of the ones I tried had those sprinkles all over the screen, just weren't clear
    03-01-2016 11:30 PM
  4. Rose4uKY's Avatar
    My Best Buy Mobile said they were going to have the Zagg Glass ones but their expensive. Last year they gave us 20% off. But I said I was coming tomorrow to pre-order the edge. I am hoping they have one for the edge. My husband was upset the defender isn't made for the edge and he may get the regular S7. Ever since I tried Zagg but their high it's been on my M8 and M9 my favorite. But it does seem like it would be hard to make one for the edge.
    I just typed in at Amazon samsung tempered glass for the 7 edge and a fewcame up so I'll get one there and not worry about Zagg I guess. The one I saw that came in all 3 colors to match your phone says not shipping till 3/27 I just noticed that. Now I'm wondering I should just get the 7 I loved having the glass Zagg on my last 2 HTC's. I don't want plastic. But let me know what you guys find and who's using what?
    03-02-2016 12:02 AM
  5. zipro's Avatar
    just make sure you get one that says "no sprinkles" on it. All of the cheaper ones I tried for the S6 EDGE+ messed up the screen experience. If it says "98% clear" it's probably one with the dreaded sprinkles.
    Rose4uKY likes this.
    03-02-2016 07:32 AM
  6. htc fan89's Avatar
    Just get uag case its like ottobox
    03-02-2016 07:51 AM
  7. Rose4uKY's Avatar
    I am wanting the Samsung cover case and will get one other maybe a commuter but I just have always had a screen protector on my phones and just started using Zagg Glass when we got our M8's and loved it so we did the same for our M9's. Their is a Zagg Kiosk in the mall where I am going right by the BB mobile so I am going to talk to them. Maybe they will have the cheap one for 14.99 that is listed on their website when you type in the S7 Edge all that it shows available is their original one but if they were to have it and put it on for me I would get that to hold me over and maybe they will eventually make a glass one. I'll have to google uag case thanks! I am leaning towards this but it's expensive https://forums.androidcentral.com/e?...token=VYS9cDrV
    03-02-2016 10:36 AM
  8. JerseyBiker's Avatar
    There is a glass screen listed on Amazon for $20 from a company by the name of Luvvitt. It's curved and covers the whole screen. The top and bottom is colored to match the color of your phone's bezels. The reviews for the S6 Edge version seems to be pretty good. The downside is that it will not be in stock until March 19 and ship dates are between March 24 to 28. It's not an Amazon Prime item so you probably will have to pay shipping also. There are not many glass screens available for the S7 Edge. Most of them only cover the front of the screen and not the edges. I should have my S7 Edge by the end of the week. I don't know if I want to go too long without screen protection. I definitely do not want plastic protector or a glass one that doesn't cover the edges. I may as suggest just get a cheap plastic one to hold me over until more glass options are available. I do not have enough post to include a link but you should be able to find it on Amazon.
    03-06-2016 07:36 PM
  9. KimJongOMG's Avatar
    There's a glass protector thread in here somewhere. Someone mentioned in there they spoke with ZAGG and he was told ZAGG is estimating sometime in the summer or fall of this year is when the tempered glass screen protector for the S7E will be released.
    03-06-2016 08:47 PM
  10. Rose4uKY's Avatar
    They emailed me the other day and said 2-3 weeks maybe a little longer.
    03-06-2016 08:55 PM
  11. pst23's Avatar
    Thats crazy - what do we do until then lol
    03-06-2016 08:58 PM
  12. Rose4uKY's Avatar
    Those ones on amazon in colors to match your phone seemed ok. I just like going to the Zagg kiosk at the mall and having them put it on. They do a good job and do it quick.
    03-06-2016 08:59 PM
  13. KimJongOMG's Avatar
    Let's just hope they can make good on that promise. I would be dead if I held my breath for their S6E protector.
    03-06-2016 09:42 PM
  14. joymariah041's Avatar
    I don't know if we are allowed to post links here? I just bought two tempered glass screen protectors with two day fed ex shipping included for $24.00 and some change. You can PM me for the link?
    03-07-2016 12:20 PM
  15. SR45's Avatar
    You can post a link but you need 10 posts or more to do so...
    03-07-2016 02:06 PM
  16. JerseyBiker's Avatar
    Does the screen protector cover the sides or just the front? Can you provide the name of the screen protectors and where you found them please? Thanks
    03-07-2016 02:27 PM
  17. Rose4uKY's Avatar
    Yes please post the name and where you found them and it's for the edge? Does it cover the sides too?
    03-07-2016 11:37 PM
  18. Rose4uKY's Avatar
    Ok so I didn't know this but my Best Buy mobile store in the mall said they all use the HD Zagg and it's good and better than the original. He said you want the HD cause of the phone but he said sometimes Zagg lets you upgrade and I called the Kiosk back in the mall and he said yes if this one is 25 than I can just pay 15 for the glass when it comes out plus though to put it on you pay but that's ok by me. So for now I'll get the HD and when the glass does come out maybe I'll wait and see what others have to say about it.
    03-08-2016 11:54 AM
  1. Replies: 2
    Last Post: 03-03-2016, 03:05 PM
  2. Where did my chrome bookmarks go?
    Last Post: 03-02-2016, 05:34 AM
  3. the quick access screen keeps popping up on my samsung galaxy s6
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-01-2016, 12:04 PM
  4. Can I use just one group instead of having contacts listed?
    Last Post: 03-01-2016, 11:58 AM
  5. Replies: 1
    Last Post: 03-01-2016, 09:54 AM
