06-07-2016 01:50 PM
331 ... 34567 ...
tools
  1. pst23's Avatar
    Nice to see I wasn't only one! I took mine back. Ordered a black one
    you didn't want to try another silver one?
    03-09-2016 07:32 PM
  2. elir41's Avatar
    I noticed a crash when trying to get into the Do Not Disturb settings.
    03-09-2016 08:37 PM
  3. mc4nam's Avatar
    I had a weird event 3 times today.
    Home button and previous apps button quit working. Had to use back arrow to get anywhere. Rebooting fixed it every time. Hasn't happened in about 4 hours now. I dunno?
    03-09-2016 08:59 PM
  4. BBBold-calgary's Avatar
    Big fan of the S7 (just like i was of the S5 and S6!)
    Have found one issue that I cannot figure out. In short, I cant seem to pair the phone to my 2011 Benz E550 (W211). It pairs but then it does not allow phone or mediia connection. Interesting enough, it does keep the contact connection. Have tried to reset / re-pair the phone several times, same for the head unit on the car. I have paired other headsets to the phone and it seems to be OK. Just to my car... Note the S6 worked fine.
    Any suggestions?
    03-09-2016 09:20 PM
  5. hls811's Avatar
    I just got my S7 Edge yesterday, its been working all day until now. I'm having this same thing, but a reboot ISN'T fixing it! The home button works to wake the screen, so I know its registering it but once the device is unlocked hitting Home doesn't do anything. The back button works, but he other one does (the one to the left of home.. Task Manager/previous apps?) doesn't do anything either. I tried to uninstall some of the last apps which may have been updated but no luck... I just got everything set up the way I had it before - I really dont want to have to wipe this thing and start over..
    03-09-2016 09:40 PM
  6. JiiPeee90's Avatar
    Is this rear camera distortion problem in every S7? Clearly visible in the straight lines. I have Sony sensor in my Edge.
    This is taken with my phone:
    03-10-2016 07:47 AM
  7. SurfnSun's Avatar
    This thread is not giving me the warm fuzzies about my first android phone. Already thinking about swapping for an iPhone 6s if my experience goes like some of these.
    03-10-2016 08:05 AM
  8. runamonk's Avatar
    I was just thinking the same thing, except I don't use an iphone, I have an Experia Z3.
    03-10-2016 08:21 AM
  9. Thors_Hammer's Avatar
    Having same issue with Home Button, suddenly not working - I rebooted and Home Button is now working....
    03-10-2016 08:26 AM
  10. Thors_Hammer's Avatar
    Anyone having issues with "dead spots" on the screen. I touch the screen and nothing happens, touch again and it responds...
    03-10-2016 08:45 AM
  11. kman00's Avatar
    Haven't had issues like that. Suggest you download the app "phone tester" one of the options is multi-touch you can basically touch the screen and it lights up. Would be a good way to test your screen.
    Very nice little app. Tells you a lot about your phone. Great tool to have.
    03-10-2016 09:50 AM
  12. kman00's Avatar
    I personally am happy with mine so far. Is there any specific issues you're having? Didn't go through every page 😶
    03-10-2016 09:53 AM
  13. gokartracer5's Avatar
    I received my edge yesterday. My only complaint so far is that my screen flickers. Especially, when the brightness is set below 50% or with auto-brightness turned on. Any idea why that might be happening?
    03-10-2016 09:55 AM
  14. kman00's Avatar
    When does it flicker? Random?
    03-10-2016 09:55 AM
  15. Thors_Hammer's Avatar
    Anyone having issues with Fingerprint recognition?
    03-10-2016 09:59 AM
  16. Thors_Hammer's Avatar
    Thanks - doing that now..
    03-10-2016 10:02 AM
  17. gokartracer5's Avatar
    It flickers randomly: on the lock screen sometimes, on the home screen sometimes, almost all the time when using auto-brightness. It seems to be alot less noticeable the brighter the screen is set to,
    03-10-2016 10:04 AM
  18. BBBold-calgary's Avatar
    I actually saw an improvement over the S6 recognition process. So, no issues...
    03-10-2016 10:11 AM
  19. ThrottleJohnny's Avatar
    Eh, that's what the forums are for. You'll find issues in every phone thread, especially right after release.
    78standards likes this.
    03-10-2016 10:18 AM
  20. kman00's Avatar
    My fingerprint scanner has been great. I come from Note 4 so for me it was a big jump when I don't have to swipe my finger and can just hold it for a sec and it opens up.
    When registering your fingerprint do you scan every part of your finger or just one spot multiple times?
    03-10-2016 10:19 AM
  21. kman00's Avatar
    That's weird, factory reset is always a good idea if you wanna try that. Worse case you can always have it replaced since most places give you the two weeks return policy. Where did you get yours at?
    03-10-2016 10:21 AM
  22. BBBold-calgary's Avatar
    i moved my finger around a bit to get most spots. that seems to be the trick to get it done.
    03-10-2016 10:24 AM
  23. kman00's Avatar
    Another suggestion is maybe delete the current scans and do a fresh one? That might help.
    Thors_Hammer likes this.
    03-10-2016 10:35 AM
  24. gokartracer5's Avatar
    I was thinking of trying a factory reset. I still have my old phone and can transfer everything over again. But, the app setup again is annoying. I pre-ordered mine through AT&T.
    03-10-2016 11:01 AM
  25. taxiron1's Avatar
    Agreed. The Samsung browser is a powerhouse compared to Chrome.
    What is the Samsung browser labeled as ? I cant find it.
    03-10-2016 11:05 AM
331 ... 34567 ...
  1. Edge + mm 6.0 update??!!!?!?!
    By kashabrown in forum Samsung Galaxy S6 edge+
    Last Post: 04-11-2016, 01:48 AM
  2. How do I connect my Galaxy S6 to my Macbook Air?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-03-2016, 05:47 AM
  3. Is there a way to turn off my S6 Edge without using the power button?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 03-01-2016, 06:27 PM
  4. Private Mode Galaxy S5
    By marie49 in forum Samsung Galaxy S5
    Last Post: 03-01-2016, 11:51 AM
  5. Replies: 1
    Last Post: 03-01-2016, 11:46 AM
