1. RJLOMMD's Avatar
    I've been quite happy with my S5 since April 2014 and, using my Verizon 2 year upgrade, I've preordered the S7 Edge. Will I be able to get the data (photos, videos and document files) from my current micro-SD card right onto the S7? Does running Android 6 make me need to re-install many of my apps (for example DejaOffice or PolarisOffice)?
    I'd appreciate your assistance
    03-01-2016 09:37 PM
  2. tcdude's Avatar
    I'm also coming from an S5 I don't think you'll have to reinstall I think it will just install itself when you log onto Google but I'll only know for sure when I get the phone next week
    nonie likes this.
    03-01-2016 10:43 PM
  3. kpreachers's Avatar
    When I went from my S3 to my S5, I had to reinstall apps, but with using Smart Switch, it transfers just about everything. You can also do it manually through the Play Store and the apps you own. I think it does this in case things aren't compatible with that device.
    03-02-2016 08:27 AM
  4. Redraider001's Avatar
    You should be able to remove the sd card from S5 and put it on S7 and good to go .. no need to do anything. As far apps data, your google account will have them and you can chose to install them manually or use smart switch
    03-02-2016 08:56 AM
  5. RJLOMMD's Avatar
    Thank you for your replies. I wasn't aware of the Smart Switch transfer utility. Will it work transferring data from the S5 to the S7? And will also transfer the data from the micro-SD in the S5 to the micro-SD I'll have in the S7?
    I use WhatsAPP and I'd like to be able to keep/transfer those data files as well. Will the Smart Switch work that as well?
    03-02-2016 03:08 PM
  1. New 6GB RAM dual edge screen phone
    By Tech-Newb in forum General News & Discussion
    Last Post: 03-14-2016, 07:47 AM
  2. Changing night clock to display on the left edge
    By bhatech in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 08:47 AM
  3. Replies: 2
    Last Post: 03-04-2016, 08:09 AM
  4. How to remove com.andoid.play?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-01-2016, 09:29 PM
  5. Why can't I seem to delete one of my Gmail accounts?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 03-01-2016, 09:16 PM
