10-21-2016 06:00 PM
1,137 ... 2021222324 ...
tools
  1. BIG CAT 7's Avatar
    Coming from the following phones in this order...
    G4>Note 5>Nexus 6P>Turbo 2
    Out of the past phones the Note 5 had awesome battery life. The S7 Edge is exactly the same. Getting 7+ hrs of SOT with this thing. Couldn't get near 4 hrs SOT with the G4, 6P ot the Turbo 2. Not sure why as I run the same set up. Anyway this phones battery life is rock solid and I will not be leaving for anything else other than possibly the Note 6 (Depending on the size). And overnight battery drain is holding at about 2-3%.
    Aquila likes this.
    03-30-2016 08:08 AM
  2. ookubanjo's Avatar
    I am getting horrendous battery life on the S7 edge. 1.5 hours SOT. 25% battery drain overnight. This is almost stock out of box. Only updated WhatsApp and running Nova Launcher Prime. All diagnostics reporting / background reporting is off, WiFi / Bluetooth scanning is off. Auto update of apps is off, location is off as I only use it when I need to infrequently use Google Maps. It's set not to use mobile networks and wifi in any case. I've disabled all crapware in the applications menu as well. I have no idea what to do, short of a cache clear and factory reset. I don't even think these would be effective but it seems like the next step. I had this same sort of battery drain on a Note 3 and 4 which leads me to believe it's Android and not the phones.
    Any ideas?
    Just to add to my previous post: my phone is clearly not sleeping. BBS shows Awake as 95% and Deep Sleep as 5%. I can't see any further detail as it requires root. Any help appreciated.
    03-30-2016 01:24 PM
  3. Almeuit's Avatar
    I am happy with this .
    Attached Thumbnails S7 edge Battery life-1459519621840.jpg   S7 edge Battery life-1459519629410.jpg
    04-01-2016 10:07 AM
  4. ironass's Avatar
    Bear in mind that battery life may depend on which model of S7 you have. Global with Exynos 8890 chip or U.S./Chinese with Snapdragon 820, as these GSMArena comparisons on the S7 Edge demonstrate.
    GLOBAL EXYNOS 8890
    U.S./CHINESE SNAPDRAGON 820
    04-01-2016 10:10 AM
  5. Mirest's Avatar
    Has anyone experienced more than usual battery drain with Bluetooth? I've had Bluetooth on for all my previous devices as well since I use it with my car and fitness band, and on S7 edge Bluetooth share is showing in the top3 most battery draining apps on Gsam. It is draining 6-7% each cycle.
    Interesting part is that it shows Bluetooth itself draining only 1% on gsam but the app Bluetooth share is the one draining the battery. Is this a Samsung thing?
    I am using T-Mobile version with SD820 if that matters.
    04-01-2016 09:09 PM
  6. Soggly's Avatar
    Now my battery drain is terrible and I can't pinpoint why, I don't think anything changed so no idea what's going on
    04-01-2016 09:14 PM
  7. Jtshurtleff's Avatar
    Finally think I got mine mostly optimized. Going to charge in the morning.
    04-02-2016 10:58 PM
  8. jianrong's Avatar
    What do you guy think of 9 hours standby wi8th sync on and few apps notifications including facebook. With drop of 8% battery.
    04-03-2016 05:37 AM
  9. Palladium65's Avatar
    Is this normal ?
    Hardly used my phone as I been sick past two days.
    S7 edge Battery life-uploadfromtaptalk1459680812144.jpgS7 edge Battery life-uploadfromtaptalk1459680818642.jpgS7 edge Battery life-uploadfromtaptalk1459680826934.jpgS7 edge Battery life-uploadfromtaptalk1459680834682.jpg
    04-03-2016 06:54 AM
  10. RichBrown68's Avatar
    How do people get to that screen like the guy had in the video that tells his screen on time? I can never find it under battery in settings. The way I calculate screen on time is X using my phone a full hour without turning it off and saying how many percent of lost in that hour. Anytime I do that with the S7 Edge, I lose 12%. So by my calculation, that's about eight and a half hours screen on time, but that's so much more than what this guy is bragging about, I'm wondering if I'm doing something wrong.
    04-03-2016 07:39 AM
  11. Palladium65's Avatar
    When you're under battery ... you have to click on "Screen"
    That will show you the screen on time
    04-03-2016 07:41 AM
  12. RichBrown68's Avatar
    Okay when I go to screen, it says time on on: 23 minutes. I'm pretty sure my battery life is better than 23 minutes. LOL
    04-03-2016 07:44 AM
  13. Palladium65's Avatar
    Post a screen shot of your battery and screen on time. .
    So we can see if it's okay
    04-03-2016 07:46 AM
  14. RichBrown68's Avatar
    I would also point out that my personal method of just counting how many percentages I lose during an hour when I'm actively using the phone was pretty much in line with reported battery life on the S7. By that method, I was losing about 20% an hour, which seems to extrapolate to 5 hours screen on time.
    04-03-2016 07:46 AM
  15. RichBrown68's Avatar
    I'll see if I can post one, but I'm confident it's okay. My complaint is not that I'm not getting enough battery life , I'm just wondering if I'm calculating it wrong because it would seem to suggest I'm getting insanely better battery life than even others are reporting.
    04-03-2016 07:48 AM
  16. RichBrown68's Avatar
    The settings under battery totally confuse me. LOL. But this is what it reports right now
    04-03-2016 07:50 AM
  17. RichBrown68's Avatar
    More
    04-03-2016 07:51 AM
  18. RichBrown68's Avatar
    And finally
    04-03-2016 07:52 AM
  19. Palladium65's Avatar
    Okay now in that click battery usage.
    Then look for screen and click on screen
    04-03-2016 07:52 AM
  20. RichBrown68's Avatar
    Just had a thought that might clarify it. When it says come on, are people checking this when their phone is close to 0 and then this tells them how long their screen was able to be on before reaching that point? Because I just started using my phone off of fresh charge.
    04-03-2016 07:57 AM
  21. Palladium65's Avatar
    Yes. Basically check it around 15% without charging it in between. Then upload screen on time pics
    04-03-2016 08:00 AM
  22. RichBrown68's Avatar
    Gotcha. Will do. this will test my OCD about never letting my phone get below 50%, but I'm up to the challenge. LOL
    04-03-2016 08:05 AM
  23. Tech-Newb's Avatar
    Is this normal ?
ID:	223193Click image for larger version.
ID:	223194Click image for larger version.
ID:	223195Click image for larger version.
    Its good! My mom's S7 edge usually sits around 1 and a half day of battery life with 5 hours screen on time. Im so jealous of the battery life on S7 edge as my S6 edge hardly survives a day.
    Posted with ❤LOVE❤
    Palladium65 likes this.
    04-03-2016 08:23 AM
  24. Palladium65's Avatar
    The best would be to charge your phone when it says so. Comes up with a notification to charge at a 15% .
    04-03-2016 09:47 AM
  25. RichBrown68's Avatar
    That would kind of negate the point of buying the wireless charger.
    04-03-2016 10:43 AM
  1. Replies: 10
    Last Post: 03-12-2018, 04:36 PM
  2. S7 and Google Messenger instead of Messages?
    By oceanclub in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 02:21 AM
  3. Anyone thought of leaving the V10 for the S7?
    By Knightstalker in forum LG V10
    Last Post: 03-19-2016, 11:55 PM
  4. Replies: 2
    Last Post: 03-15-2016, 03:46 PM
  5. V10 Battery - so much better than I expected.
    By Mister K in forum LG V10
    Last Post: 03-15-2016, 12:52 PM
