10-21-2016 05:00 PM
1,137 ... 2223242526 ...
tools
  1. Soggly's Avatar
    Same honestly, no idea what it is
    04-08-2016 05:18 PM
  2. Iva_LadyDiCaprio98's Avatar
    I've been experiencing same issues it started just a couple of days ago where I noticed that it started draining faster than usual and I haven't changed the way I've been using the phone or anything so I don't get why it's acting up all of a sudden
    Tarah Sorber likes this.
    04-08-2016 07:19 PM
  3. Tarah Sorber's Avatar
    Frustrated because I was getting great battery life. Now all of a sudden this unexplained battery drain.
    04-08-2016 08:38 PM
  4. xocomaox's Avatar
    Here is my standard 50% power stats for battery life. Seems like this is becoming the average for me on auto brightness, favoring WiFi, gaming a bunch, AOD on the whole time.
    04-08-2016 08:42 PM
  5. erasat's Avatar
    Again, have you cleared Apps cache and did the Clear Cache Partition in Recovery Menu? I can tell you that it can take care of whatever bug may be causing issues on your phone.
    It's a known thing to at least do the Clear Cache Partition after any updates, it deletes all system files cache and force them to be re-created with new OS files, Even when no updates have been done, if you see or think that your phone is showing any unknown behaviors it may only helps, it won't do any harm.
    04-08-2016 08:45 PM
  6. Tarah Sorber's Avatar
    I did what you said. Cleared the cache. Then did the recovery mode. It jumped into "installing update" but then it failed and a asked me if I wanted to boot the phone normally.
    04-08-2016 08:51 PM
  7. erasat's Avatar
    Installing update? Was that after you enter to recovery menu and did the Clear Cache partition or you never got to the Recovery menu? If you couldn't enter to recovery menu, just give ti another try, if you press Home and Volume Up buttons first and keep them pressed while pressing and hold the Power button for a couple of seconds at least, it should enter the Recovery Menu.
    04-08-2016 08:55 PM
  8. Iva_LadyDiCaprio98's Avatar
    I have cleared the cache partition yesterday and it was still draining for no reason and did it again today. Will see if it'll hold up after I charge my phone.
    04-08-2016 10:06 PM
  9. Soggly's Avatar
    Did this already, no difference :/
    04-09-2016 04:43 PM
  10. Andyvalver's Avatar
    Update on my battery life. Best results so far. Whole day with 23% left and was about to easily pass 6 hours screen on time if I wasn't going to bed. This is on my s7 edge.
    Posted via S7 edge 😍
    04-11-2016 11:15 PM
  11. Andyvalver's Avatar
    Second screen shot
    04-11-2016 11:16 PM
  12. dizzll's Avatar
    It is good, iPhone 6+ was about 2 hours better SoT. I'd rather have my Samsung though.
    04-11-2016 11:38 PM
  13. jeetu4444's Avatar
    Samsung S7 Edge exynos some crazy SOT vs Sd 820 s7 edgeS7 edge Battery life-194547.jpg
    Posted via My Awesome Lumia 950 ds red and gold or LG G4 or surface pro 4
    ironass likes this.
    04-12-2016 05:30 AM
  14. Andyvalver's Avatar
    That looks mad. Mine has the exnyos processor.
    04-12-2016 07:17 AM
  15. Kristian Nikolov's Avatar
    I can also say that my S7 Edge started draining a lot faster for the last few days. No new apps were installed, nothing changed or nothing unusual happening, it just drains faster.
    04-12-2016 02:44 PM
  16. Iva_LadyDiCaprio98's Avatar
    Yeah I tried the clearing cache partition. It worked for a couple of days and now the issue is back again. Battery draining faster and Android system taking up most of the battery
    04-12-2016 04:57 PM
  17. Hapa_Dude's Avatar
    I'm a bit disappointed in the battery life. Do you use Power Saving mode? It seems more aggressive than my S4, like Pandora will not play the next song, it will just stop at the end of the current song when in S7E's Power Saving mode.
    My SOT is only 4.5 hours and tons of System usage. Any tips how to reduce system usage? I've been using the phone lightly the last few days.
    04-13-2016 01:10 AM
  18. Hapa_Dude's Avatar
    The Android Central app lets me select multiple attachments but only posted the last one, so here are the other screenshots. Overnight the phone was in airplane mode. During the day I'm on LTE, at night WiFi at home.
    04-13-2016 01:31 AM
  19. Hapa_Dude's Avatar
    The loooooooong list of stuff running in the system. How do I cut out some of that junk?
    04-13-2016 01:32 AM
  20. Stuart Adams1's Avatar
    Had no problems with my battery life. This thing lasts forever heavy usage and still getting 1 day 15 hours plus out of one charge. Also this is the only device I haven't wanted to root straight away and don't think I will.
    04-13-2016 02:48 AM
  21. erasat's Avatar
    If your disappointment is seeing the Android System at the top, then relax a little, it seems that you won't get rid of that unless something changes with a new OS Update. If what it has been told it's true the High Android System shown is because of some processes running with the Snapdragon 820 chipset, people with Exynos version are not getting this, but basically most people with the US variant and the SD820 have the "issue".
    Please note I mentioned "issue" because knowing that it's not an app or a phone problem you have to see it as it is, nothing that you can do about it, and even with that (it's the first time I have a phone with similar behavior) I still get the best battery life I've got on a phone, averaging 7 hours of SOT since I got it on March 11. Your SOT even when it's a lot less than mine doesn't mean it's bad, everything depends on individual usage.
    Hapa_Dude likes this.
    04-13-2016 09:58 AM
  22. Almeuit's Avatar
    I am not really seeing an issue. 1day + on battery with almost 5 hours of SoT seems pretty reasonable.
    04-13-2016 10:27 AM
  23. t11rmh's Avatar
    Double post.
    04-13-2016 11:18 AM
  24. t11rmh's Avatar
    This is my useage today. I'm not really worried about Google Services being at the top.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    04-13-2016 11:20 AM
  25. BillyC517's Avatar
    Hi All,
    Have the S7 Edge here as well. Noticed last night a 22% drop in my battery. Nothing running, face down. Over the last few days I have noticed that the battery is draining quick. I turn phone off at night and charge. During the night I unplug the phone when I see the green indicator light, showing that it is fully charged. When I turn it on in the morning, it takes less than 2 mins to drop to 99%.
    What is going on with this battery!?!?
    Bill
    04-13-2016 01:08 PM
  1. Replies: 10
    Last Post: 03-12-2018, 03:36 PM
  2. S7 and Google Messenger instead of Messages?
    By oceanclub in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 01:21 AM
  3. Anyone thought of leaving the V10 for the S7?
    By Knightstalker in forum LG V10
    Last Post: 03-19-2016, 10:55 PM
  4. Replies: 2
    Last Post: 03-15-2016, 02:46 PM
  5. V10 Battery - so much better than I expected.
    By Mister K in forum LG V10
    Last Post: 03-15-2016, 11:52 AM
