10-21-2016 05:00 PM
1,137 ... 2324252627 ...
tools
  1. HOLLYWOODANT215's Avatar
    Ever since the sprint update, it's been draining fast
    imex99 likes this.
    04-14-2016 01:44 AM
  2. ironass's Avatar
    These 2 videos demonstrate the battery life and usage for the Korean manufacturer's own Samsung octa core, Exynos 8890 chip that is installed on all their Global and Canadian S7 and S7 Edge models and already labelled by some as, "The Beast from the East".
    Samsung Galaxy S7 Edge - Battery Life Test Comparison Review! (Exynos 8890)
    Samsung Galaxy S7 edge battery life (Exynos and Snapdragon)
    04-14-2016 03:04 AM
  3. erasat's Avatar
    Have you cleared Apps cache on Settings-Storage and Wipe cache Partition on recovery menu? If not, do so, it's always recommended to do at least a Wipe cache partition after every OS Update.
    Also, just double check all things you may be disabled, like bloatware or other services and apps that could have been reactivated after the update, I have seen that before and it may be the difference you are seeing.
    04-14-2016 12:44 PM
  4. BillyC517's Avatar
    Hi All,
    Still having quick battery draining issues. Just did Cache Partition Wipe. Will see what that does.
    BC
    04-14-2016 12:59 PM
  5. erasat's Avatar
    It's weird, I did exactly what you said about a week ago. Then a couple of days ago as my post quoted, I was at 55% and at 5 and a half hours of screen on time. And then it hasn't been that good since.
    Then you definitely should have a system app or feature causing the extra drain, problem with that is that most of the time those are all mixed into the Android System bucket and that makes it even harder to pinpoint.
    clintw22 likes this.
    04-14-2016 07:40 PM
  6. ilordvader's Avatar
    No. Nova. Noooooooooooooooooooooooooooooooooooooooooo.
    After much dismay and using Nova for over 7 years, I had to let it go. Long story short, Nova Launcher was keeping my phone awake the entire time the phone was on. I am NOT saying that it's everyone's problem, but unfortunately for me and MY phone it was causing my phone not to deep sleep. After removing Nova, I began to setup Touchwiz, my phone rebooted by itself and the phone was super warm. After removing it, my phone now sleeps like a baby. I expect that my massive drain will end. Again this may not be everyone's problem, but for me I had to let it go. Sorry Nova, Touchwiz works just fine for me right now.
    APEX is Best
    04-15-2016 02:21 AM
  7. BillyC517's Avatar
    Hi All.
    Another update. I did another overnight test, AFTER wiping the system Cache, all apps closed, not plugged in, face down, for 7 hours. The last 2 nights, I lost over 20% each night. After doing the Cache wipe, I only lost 4%.
    I think the Cache wipe helped. I will charge it fully today, and see how it lasts.
    BC
    04-15-2016 07:45 AM
  8. Iva_LadyDiCaprio98's Avatar
    Yeah sometimes it's best to clear out cache on case there's a faulty file or something that constantly keeps the phone awake. I'm still trying to figure out why mine isn't doing as well anymore and I've already done two cache wipes.
    04-15-2016 08:49 AM
  9. Malek J's Avatar
    This is the best I've gotten so far. Exynos variant
    04-15-2016 05:56 PM
  10. jeetu4444's Avatar
    Soo guys after having my beautiful S7 edge for 7 days lying in the box today was the 1st day I started using it..As it was 1st day lot of use from apps downloads...to stuff transfer from old phone...battery is superAttachment 224747S7 edge Battery life-1078.jpg
    04-15-2016 08:27 PM
  11. Soggly's Avatar
    What the hell happened, my screen on time just magically doubled lol, it still says I have about 2 more hours so 10 hours of screen on time?? No idea why
    04-16-2016 04:28 AM
  12. Soggly's Avatar
    2nd
    04-16-2016 04:29 AM
  13. iSnoopy 7e's Avatar
    I got 3 hours SOT already and I still have 60% left. Battery life on this thing is AWESOME.
    I'd love to post my screenshot if you guys would teach me how to. I'm using mobile browser
    Exynos version here
    04-16-2016 11:21 AM
  14. jeetu4444's Avatar
    Guys even post which processor yr phones have...like mine is exynos..which suppose to have better battery life than sd 820
    Posted via my Awesome Lumia 950 , Beautiful S7 Edge Gold or Surface pro 4
    04-16-2016 12:33 PM
  15. Soggly's Avatar
    Mines the snapdragon hence my confusion lol
    04-16-2016 12:43 PM
  16. Truman82's Avatar
    Well I noticed that if i try to get a lot of stand by time for the phone,then I won't get good on screen time. For the past 8 hours I have used the phone a lot, not much stand by. So far SOT is 5h24m and have 38% left.
    When the phone is mostly idle and only casual use i get about 3-4h SOT and stand by of 24-35h overall time before battery dies on me.
    04-16-2016 11:27 PM
  17. Truman82's Avatar
    Now only to get fix on that dang video shooting problem!then I'd be happy to have 99% perfect phone!
    04-16-2016 11:29 PM
  18. iSnoopy 7e's Avatar
    What is this particular problem? Haven't heard nor experienced any vid shooting problems so far
    04-17-2016 12:59 AM
  19. Truman82's Avatar
    Well the OIS in the camera applies effect to the video like there would be water in lenses. Software OIS eliminates this but if you disable the software OIS the effect is apparent.
    Just heard it works as intended?
    04-17-2016 03:38 AM
  20. dizzll's Avatar
    I'm wondering 2 things.
    1. How does the Exynos get 20% more battery average?
    2. How does the iPhone with a 30% smaller battery get 2 more hours SoT even with power saving enabled on my S7?
    04-17-2016 10:20 AM
  21. jeetu4444's Avatar
    Simple iphone doesn't have 2k screen...and samsung has managed to adjust the processor better than sd 820
    04-17-2016 10:24 AM
  22. ironass's Avatar
    Alternatively. the Exynos octa core is a more powerful processor than the overclocked quad core Snapdragon 820.
    04-17-2016 02:05 PM
  23. Truman82's Avatar
    Apple has engineered the software to work with custom hw they make for it. So it is extremely efficient system.
    04-17-2016 02:28 PM
  24. 2high4u's Avatar
    I own the exynos variant of the s7 edge and here's what I constantly get after a month with the phone:
    With wifi only : 8-9H SOT
    With cell data only : 6H SOT
    Mix of both depending on the usage 6-8H SOT
    Some of you may ask me what kind of setting is set on my phone well here's the list :
    - Bluetooth is on sometimes
    - GPS off
    -AOD off
    - Power saving off
    - Brightness on auto
    - All my notifications/sync are push
    But the common problem I found with battery drains comes from Facebook and instagram. I told my friends to set the ''auto play'' in the settings to ''wifi connections only '' and most of them definitely found a better improvement over their battery.
    04-17-2016 06:04 PM
  25. jianrong's Avatar
    Many apps still in background... app like facebook...
    04-17-2016 06:05 PM
  1. Replies: 10
    Last Post: 03-12-2018, 03:36 PM
  2. S7 and Google Messenger instead of Messages?
    By oceanclub in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 01:21 AM
  3. Anyone thought of leaving the V10 for the S7?
    By Knightstalker in forum LG V10
    Last Post: 03-19-2016, 10:55 PM
  4. Replies: 2
    Last Post: 03-15-2016, 02:46 PM
  5. V10 Battery - so much better than I expected.
    By Mister K in forum LG V10
    Last Post: 03-15-2016, 11:52 AM
