10-21-2016 05:00 PM
1,137 ... 2728293031 ...
tools
  1. aldo82's Avatar
    My android system usage is at 23% today and I'm down to 50% battery with just 1.5 screen on time. Is there any way to fix this?
    05-07-2016 01:18 PM
  2. pjwk81's Avatar
    I uninstalled Nova after reading the post today. At the time (after around 4 hours off charge) I had 2h56m Stay Awake. In the 6 hours after uninstall it was only at 2h58m.
    05-07-2016 02:50 PM
  3. aldo82's Avatar
    I'm just using the touch wiz launcher. Does a factory reset fix the android system drain or is it a waste of time?
    05-07-2016 03:29 PM
  4. orlans21's Avatar
    im not sure if a factory reset brings it back to the original version and im not willing to find out for myself. ive put too much work into my set up already
    05-07-2016 03:43 PM
  5. clownin72's Avatar
    Right now I'm about 6 hours off charge and android system is at 27% screen 15% . Not anything better than my note 4 was. I've tried everything
    05-07-2016 04:16 PM
  6. aldo82's Avatar
    CPU total for android system is 4 hours 32, with it using 28% battery. 2 hours screen on time and 32% battery left. Pretty rubbish really!
    05-07-2016 04:34 PM
  7. tengtengvn's Avatar
    I have the t-mobile S7e. Wifi On most of the time. Hopefully I'll get close to 8hrs SOT on this charge.
    05-07-2016 05:07 PM
  8. zkyevolved's Avatar
    S7 edge Battery life-screenshot_20160508-080114.jpgS7 edge Battery life-screenshot_20160508-080119.jpg
    I charged it to 100% before going to bed. Cleared all apps before going to bed out of the multitasking tray and it had 15min of SOT. nearly 8 hours later this is what I got! This is, honestly, pretty bad. I expect more ...
    05-08-2016 01:19 AM
  9. optimummind's Avatar
ID:	226941Click image for larger version.
    Yea, that is bad staying awake for 7 hrs. Google needs to fix their **** & get their act together. I'm so sick of Google messing up the battery life on Android phones. It's been like this since I started using my Android device which was a Galaxy S2.
    05-08-2016 02:40 AM
  10. marzfreerider's Avatar
    The battery on mine has been better than all my previous phones (the PRIV was good but this has been better). I've been on battery for 12h 38m 22s with a screen on time of 3h 49m 7s, still have 59% battery left. I've been doing some emails, Internet use, phone calls and texting.
    05-08-2016 03:44 AM
  11. aldo82's Avatar
    Barely touched my phone this morning and android system is at 42%! Is just eating up my battery. Feels like factory reset time to me...
    05-08-2016 04:13 AM
  12. thegame161's Avatar
    Not sure why my battery life has been so bad
    Went from 97% to 60% overnight
    05-08-2016 05:26 AM
  13. aldo82's Avatar
    Battery life is probably my biggest frustration with android. Get a phone with a nice big battery, see all the reviews saying how good it is. Experience it first hand for a bit and then something changes and it all goes wrong. No new app installs, nothing obvious, just big battery drain for no apparent reason. Maybe Google pushed an update to play services that did it I'm not sure but it's seriously annoying. Feel like I want to try a factory reset but don't want to do it if it won't make any diffidence!
    optimummind likes this.
    05-08-2016 05:37 AM
  14. pjwk81's Avatar
    Another pretty poor day with mine. Granted, over 5 hours screen time is good but before the latest update a day like today (not using 4G) would have easily hit 9 hours. That Android System drain and Stay Awake time is completely massive compared to before the APD3 OTA broke it.
    05-08-2016 05:51 PM
  15. the game 161's Avatar
    better today
    Only drained 10% overnight in 10 hours than 37% in 7 hours the night before
    05-09-2016 02:45 AM
  16. chanchan05's Avatar
    I am not sure why you're expecting differences in android system percentage use and screen percentage use from your previous phone. Percentages should be the same. Uptime should make a difference though. Or were you talking about the 6hrs?
    05-09-2016 03:02 AM
  17. aldo82's Avatar
    Has anyone with android system drain done a factory reset? Did it fix the problem? I'm tempted to try but it's a bit of a pain so don't want to bother only to find the problem still there!
    05-09-2016 03:12 AM
  18. Spade30's Avatar
    I experienced the samee issue after the at&t update, I couldn't figure out what the problem was until I went into the developers settings and changed all animations to 0.5 and everything changed I went having 16hrs of battery life to 1 day 1.2 hrs and 7hrs of sot compared to 4hrs sot.im just sharing my experience I can't say it will work for everyone
    05-09-2016 03:17 AM
  19. MasterRy88's Avatar
    One of my biggest issues was changing the location setting from High Accuracy to GPS Only, that alone allowed my phone to doze properly and lose only 3-5% overnight. This is on a VZW model.
    05-09-2016 01:38 PM
  20. pjwk81's Avatar
    I was going to try that but the phone would't allow loaction added to camera photos with it on GPS only.
    05-09-2016 01:42 PM
  21. pjwk81's Avatar
    Is there any way to turn off the WiFi constantly scanning once connected to a WiFi network? This must be a huge battery hog but it's the first phone I've had that doesn't seem to have the 'Advanced' WiFi settings menu.
    05-09-2016 05:18 PM
  22. aldo82's Avatar
    Wi-Fi scanning is within improve accuracy part of location settings
    pjwk81 likes this.
    05-09-2016 05:20 PM
  23. pjwk81's Avatar
    Thanks. Just knocked it off there.
    05-09-2016 05:23 PM
  24. Lance Redden's Avatar
    I keep hearing mixed reviews about battery life. I have the s7 Edge and I get decent battery life. It's usually about a 10% drain per hour maybe even more. That's with almost all features shut off (Always on display, Edge features, auto~snyc, location services, screen about 50%,). Not sure if this is normal or not. What do you all think ?
    Posted via the Android Central App on S7 Edge
    05-09-2016 05:35 PM
  25. orlans21's Avatar
    what baseband version are you running? if it ends with APD3 or under you have the battery drain bug
    05-09-2016 05:59 PM
  1. Replies: 10
    Last Post: 03-12-2018, 03:36 PM
  2. S7 and Google Messenger instead of Messages?
    By oceanclub in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 01:21 AM
  3. Anyone thought of leaving the V10 for the S7?
    By Knightstalker in forum LG V10
    Last Post: 03-19-2016, 10:55 PM
  4. Replies: 2
    Last Post: 03-15-2016, 02:46 PM
  5. V10 Battery - so much better than I expected.
    By Mister K in forum LG V10
    Last Post: 03-15-2016, 11:52 AM
