10-21-2016 05:00 PM
1,137 ... 3435363738 ...
tools
  1. Lance Redden's Avatar
    Took off the charger around 8, @ 100%. Because I called off sick today, I've been using my phone pretty much non stop. Surfing the web, on the forum. Researched, and shopped for a case for my phone.
    FORGOT to add phone was 61%
    Battery graph or it didn't happen
    Posted via the Android Central App on S7 Edge
    05-27-2016 02:16 AM
  2. bullittmustang's Avatar
    Standby times on my T-Mobile S7 Edge are outstanding. I don't always screen cap them so these are two recents I have. Two different S7 Edge.
    Attachment 228349
    Attachment 228350
    That is amazing. Did you use it at all, or is that all standby?
    05-27-2016 08:27 PM
  3. NexusGirlX's Avatar
    On the top one, I did use that phone off and on through the day. You can see where the graph dips each time. The second phone i didn't use much at all.
    05-28-2016 02:01 AM
  4. love4speechless's Avatar
    Beast battery life
    Attached Thumbnails S7 edge Battery life-1464453448172.jpg   S7 edge Battery life-1464453462662.jpg
    05-28-2016 11:37 AM
  5. hishaq96's Avatar
    Why am I getting poor battery life
    Attached Thumbnails S7 edge Battery life-1464618234233.jpg   S7 edge Battery life-1464618250103.jpg
    05-30-2016 09:24 AM
  6. coolkenny13's Avatar
    @hishaq. did you recently update your phone. the april update caused alot of problems for people. minor heating issues + drain.
    how was your battery before the update?
    05-31-2016 01:43 AM
  7. the game 161's Avatar
    That's not bad
    I get on average 4-5 hours screen on time and you are more than on target for 5 at least
    05-31-2016 05:14 AM
  8. hishaq96's Avatar
    Thanks for your reply yes I did update the phone. The battery life was quite good it has changed since I factory reset the phone
    05-31-2016 05:43 AM
  9. hishaq96's Avatar
    That's not bad
    It may seem like I am going to get 5 but I be lucky to even get 4hrs
    05-31-2016 05:44 AM
  10. KPMcClave's Avatar
    I think people's confusion is in not realizing that you've been comparing your own battery currently to your own previously.. For a lot of folks, your current averages are decent battery life.
    There are so many variables that it's hard to compare person A to person B to person C in battery life, but if your own averages drop with no changes in usage or locations, that's about the most insightful comparison we can get.
    05-31-2016 06:32 AM
  11. Badboy8813's Avatar
    I did a factory reset and did not setup google fit this time around. My battery life is much more improved now.
    05-31-2016 08:57 AM
  12. bembol's Avatar
    Not that I'm complaining about my S7 but battery life on the edge is the other reason why I upgraded.
    Fully charged Sunday night around 11 and still have 40%.
    Xsie likes this.
    05-31-2016 09:19 AM
  13. Doc Marten's Avatar
    I don't think so. Do you have AOD on? I lose just about 5% overnight.
    I've noticed a massive improvement over the last few days. Last night for example, I went to bed with the phone at 100% and got up this morning 10 hours later and the battery is on 98%. Wifi and location are still on but I switched off LTE4 and selected '3G/2G Auto Select' as we don't get LTE4 here yet. I'm not sure if that's what made the difference or whether a new S7 just uses more battery in the first couple of weeks as it works out your usage patterns etc.
    Anyway I'm delighted with that kind of battery usage.
    06-04-2016 04:08 AM
  14. chanchan05's Avatar
    Oh that explains it. Your phone was keeping on searching and searching for a 4G signal that's why it was draining power.
    06-04-2016 05:45 AM
  15. love4speechless's Avatar
    I find that even though I have a low 4G signal the battery drains faster on 3G coverage than my low 4G signal
    06-04-2016 05:00 PM
  16. love4speechless's Avatar
    Wow I've never seen Freeplay run in the background like this. Does anyone know how to stop apps from running in the background?
    Attached Thumbnails S7 edge Battery life-1465079101513.jpg   S7 edge Battery life-1465079112139.jpg
    06-04-2016 05:25 PM
  17. tinybfk's Avatar
    Mines been pretty good today. It's the Snapdragon 820 variant with Sprint.
    Posted via Carrier Pigeon.
    06-06-2016 12:34 AM
  18. tinybfk's Avatar
    SOT
    06-06-2016 12:35 AM
  19. tinybfk's Avatar
    One more.
    06-06-2016 12:52 AM
  20. Iva_LadyDiCaprio98's Avatar
    I've noticed something. For some reason when I charge through a cable, my phone drains so much quicker than when I charge through wireless. I can't figure out why that is though
    06-06-2016 02:30 PM
  21. pjwk81's Avatar
    This is typical of the phone of late. Awful. So disappointing when I could get between 6 and 9 hours screen on time without issue and I'm really regretting buying it now. The phone I replaced was better than this.
    06-07-2016 05:18 PM
  22. chanchan05's Avatar
    http://i65.tinypic.com/11sdwzb.png
    http://i67.tinypic.com/sdnx2a.png
    http://i64.tinypic.com/2cmx0jp.png
    http://i66.tinypic.com/10iapnp.png
    Is that an S7? Your notification bar icons look different.
    06-07-2016 07:11 PM
  23. PetitHerisson14's Avatar
    After a factory reset done a few days ago, my battery life really improved and today it was just incredible !
    S7 edge Battery life-screenshot_20160608-011526.jpg S7 edge Battery life-screenshot_20160608-011537.jpg
    love4speechless likes this.
    06-07-2016 07:20 PM
  24. love4speechless's Avatar
ID:	229574 Click image for larger version.
    You are the first person on this forum who has had screen on time higher than mine lol
    06-07-2016 07:40 PM
  25. PetitHerisson14's Avatar
    Really ? But that's not even the higher I heard of, some people talk about 10 hours of screen on time xD
    But to be fair, it was with only WiFi, no Bluetooth, no sync, no location + I disabled some things like always scanning for Wifi and always scanning for Bluetooth and I have 40 applications on saving mode. But AoD was on and I didn't use any power saving mode
    06-07-2016 07:58 PM
  1. Replies: 10
    Last Post: 03-12-2018, 03:36 PM
  2. S7 and Google Messenger instead of Messages?
    By oceanclub in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 01:21 AM
  3. Anyone thought of leaving the V10 for the S7?
    By Knightstalker in forum LG V10
    Last Post: 03-19-2016, 10:55 PM
  4. Replies: 2
    Last Post: 03-15-2016, 02:46 PM
  5. V10 Battery - so much better than I expected.
    By Mister K in forum LG V10
    Last Post: 03-15-2016, 11:52 AM
