10-21-2016 06:00 PM
1,137 ... 3738394041 ...
tools
  1. chanchan05's Avatar
    Mines draining fast 82% with only 41 mins SOT
    Were those 41min gaming? But that's still pretty high. How good is signal for you usually? On perspective, here's my usage at 81%, spend gaming on Clash of Clans and browsing Facebook and Tapatalk. Pardon the red screen filter.
    06-21-2016 11:25 AM
  2. hishaq96's Avatar
    https://uploads.tapatalk-cdn.com/2016...a51f14c1ff.jpg
    My signal is OK and with no gaming
    06-21-2016 11:46 AM
  3. aldo82's Avatar
    Battery life has to be my biggest frustration with android. This phone has such potential with a big battery and for some it works well. But for many there are hidden processes and battery drainers going on that just spoil the experience. It's a shame. Especially when the release firmware was so good and the updates have made things worse
    antodelg likes this.
    06-21-2016 12:37 PM
  4. pjwk81's Avatar
    I really thought they might have fixed it this past update. I'm probably worse for having any faith in them.
    06-21-2016 12:47 PM
  5. cardboard60's Avatar
    I'd take gsam,battery monitor and as many apps as I could off the phone.
    Apps take up battery life.
    Back up your data and reset the phone.
    06-21-2016 01:35 PM
  6. pjwk81's Avatar
    My apps don't even take up 2 pages of the drawer and I never use gsam. Reset it two days ago and after 1 good day of battery, it's back to rubbish now.
    06-21-2016 02:13 PM
  7. love4speechless's Avatar
    Meanwhile my biggest battery drain is still OS. Wish I knew what was causing it to be so high so I could turn it off
    Attached Thumbnails S7 edge Battery life-1466540781947.jpg   S7 edge Battery life-1466540791501.jpg
    06-21-2016 04:26 PM
  8. Bruins11's Avatar
    Well looks like you left WiFi direct on. That eats quite a lot of battery if left active AFAIK.
    What do you mean by "wifi direct"
    06-22-2016 05:28 AM
  9. chanchan05's Avatar
    It's basically airdrop for Android. But anyway checked the picture again, it appears the icon I mistook for WiFi Direct was actually WiFi calling.
    06-22-2016 05:31 AM
  10. Bruins11's Avatar
    Yup no worries.
    06-23-2016 01:40 PM
  11. hishaq96's Avatar
    Since the new software update I struggle to even get 4hr SOT
    Attached Thumbnails S7 edge Battery life-1466719617125.jpg   S7 edge Battery life-1466719625895.jpg
    06-23-2016 06:07 PM
  12. jeetu4444's Avatar
    I agree...with every update battery life has become less..when phone came with original software battery life was very good..now i can barely get 12 hrs..can anyone confirm that hard reset has solved the problem...
    As i have defected screen iam going to samsung to get it repaired after that will hard reset my phone..
    Posted via my Awesome Lumia 950 , Beautiful S7 Edge Gold or Surface pro 4
    06-24-2016 08:27 AM
  13. chanchan05's Avatar
    Initially the last update diminished by battery life. A cache wipe restored it. However I think my battery life can still get better. I'm seeing a massive jump in battery usage by the antenna. With mobile data off, I get 0.7% per hour, and that's with stuff like Tasker and Lightflow polling for events in the background. But turning mobile data on makes this jump to 3-4% per hour on my latest test.
    06-24-2016 08:47 AM
  14. aldo82's Avatar
    Has anyone done s factory reset and found battery life improved? I might do it but don't want the hassle for no reward
    06-24-2016 09:08 AM
  15. chanchan05's Avatar
    Try a system cache wipe first. It won't delete anything relevant, and in my case it helped.
    06-24-2016 10:23 AM
  16. aldo82's Avatar
    Thanks, already done that. So unless I try it again, it basically didn't help. Battery life gets worse with each update it seems
    06-24-2016 11:36 AM
  17. Bag of Leaves's Avatar
    Samsung will Factory Reset it for you (back up everything before you send it in). That's why I am not going to get my phone's wireless charging problem (too slow) repaired, because I do not want to spend days setting my phone up again. Obviously, it would be different if the screen were broken or something; I can live with slow wireless charging since the wired charges fast and I usually just charge it overnight.
    06-25-2016 12:23 AM
  18. pjwk81's Avatar
    Mine lost 28% overnight in 6 hours.
    06-25-2016 10:28 AM
  19. hishaq96's Avatar
    Samsung really need to do something
    06-25-2016 10:54 AM
  20. ThrottleJohnny's Avatar
    Uninstall and then reinstall all large apps after every update. Works for me every time.
    06-25-2016 11:21 AM
  21. pjwk81's Avatar
    My last cycle...
    06-25-2016 12:04 PM
  22. jeetu4444's Avatar
    I rather do hard reset...newaz once my phone is repaired and hopefully replaced..will do hard reset..hope battery life goes back to original
    06-25-2016 12:05 PM
  23. andrew_ackley's Avatar
    Uh get the exynos version it's WAY better on battery. Trust me.
    06-25-2016 09:39 PM
  24. andrew_ackley's Avatar
    Pretty sure it's the snapdragon processor.
    06-25-2016 09:40 PM
  25. andrew_ackley's Avatar
    This is mine with exynos. This is at prob 75% brightness avg all day and playing / downloading quite a few games.
    06-25-2016 09:42 PM
  1. Replies: 10
    Last Post: 03-12-2018, 04:36 PM
  2. S7 and Google Messenger instead of Messages?
    By oceanclub in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 02:21 AM
  3. Anyone thought of leaving the V10 for the S7?
    By Knightstalker in forum LG V10
    Last Post: 03-19-2016, 11:55 PM
  4. Replies: 2
    Last Post: 03-15-2016, 03:46 PM
  5. V10 Battery - so much better than I expected.
    By Mister K in forum LG V10
    Last Post: 03-15-2016, 12:52 PM
