10-21-2016 05:00 PM
1,137 ... 23456 ...
tools
  1. MuchoAloha's Avatar
    What about the non-edge version though??
    You're in the wrong forum, check out the regular s7 thread.
    03-03-2016 10:07 AM
  2. jimbo1mcm's Avatar
    A user has posted a very good review of the battery life on the S7 Edge. Looks promising.
    03-03-2016 10:55 AM
  3. PowrDroid's Avatar
    Thanks. Out of curiosity, why is it better?
    It's a heat issue. The further down you drain the battery, the longer it's going to take to charge up again. Quick Charge will run more current, thus more heat, into the battery than the older charging methods.
    I always thought it was better for the 1st few cycles of a new battery to let it go all the way down?
    I think that applied to older batteries, i.e. not Lithium batteries.
    Sometimes with an older battery whose charge is not calibrated with the battery meter, it is recommended to run it almost all the way down, then power it down and charge it overnight.
    mc4nam and ClintRo like this.
    03-03-2016 11:06 AM
  4. xocomaox's Avatar
    It's actually not heat but low power thresholds damage the cells of the battery over time. heat just corrodes them, which ultimately damages them.
    mc4nam likes this.
    03-03-2016 11:13 AM
  5. mc4nam's Avatar
    Thanks Gentleman. Not going lower than 10% anymore.
    03-03-2016 11:15 AM
  6. vtpmt81's Avatar
    Sorry for duplicate.. Here is screen on time. Still 6% left as I am typing this
    Wow is the only word I have for this kind of battery life.
    03-03-2016 11:20 AM
  7. GeorgeCorrs's Avatar
    That's good to hear that s7 has a very good battery another plus for s7 edge. Well i'm planning to buy this one but i'm still looking for a good phone. That might defeat S7 when it comes to spec lol.
    03-03-2016 01:50 PM
  8. inffy's Avatar
    By doing that you will never buy a new phone. There is always something better coming
    xocomaox and Maisoumenos like this.
    03-03-2016 01:52 PM
  9. nonie's Avatar
    I'm wondering about battery life after a few days use, if you have s7 edge with screen on on the time?
    Is there a setting to turn screen off if you want?
    Posted from Android Central
    03-03-2016 01:56 PM
  10. inffy's Avatar
    Screen can be turned off using the power button.
    03-03-2016 01:57 PM
  11. PowrDroid's Avatar
    I would guess the Always On screen would take less than 1% of battery life over an entire day. I'd probably leave it on always.
    03-03-2016 02:13 PM
  12. ThrottleJohnny's Avatar
    I will always use the AOD. I love this feature.
    03-03-2016 02:40 PM
  13. Keith Grech's Avatar
    Its alaways best to charge your lithium ion batteries once you hit 50%. Its much better to do quick burst charges (you dont always have to take it to complete 100%charge). Older batteties are a different story. Once every couple of months you can recalibrate your battery by taking it to 0% then shutting it off and giving it a full charge BUT it is not really necessary or recommended. My S5 battery is 11/2 years old and I STILL get phenomenal battery life. It is also not recommended to use your phone while charging due to overheating issues which may lead to damage. Take care of your battery and you'll see the results day in and day out!!! (Especially now that most deviced are going to non-removeable batteries) Thanks All... Keith G.
    03-03-2016 02:43 PM
  14. Keith Grech's Avatar
    They said that the S7Edge actually feels better and thinner in your hand than the S6Edge even though it's a bit thicker Thank... Keith G.
    03-03-2016 03:11 PM
  15. aalu91's Avatar
    sorry to be a downer, but battery life on my S7 Edge has NOT been good...attached are images. Any suggestions?
    Imgur: The most awesome images on the Internet
    03-03-2016 03:47 PM
  16. mc4nam's Avatar
    I am not smart enough to read into all of the stats in those pictures to tell you but your phone seems to be an outlier so far
    03-03-2016 04:03 PM
  17. Patty L's Avatar
    Well, stop snapchatting pics of your junk. Should save a ton of battery life.
    JK.
    Looks like you went over and started to really use the phone heavily mid-day. Might be the issue.
    mustgolf likes this.
    03-03-2016 04:06 PM
  18. Techno-guy's Avatar
    3+ hours of CPU time is enormous. Something is keeping your phone awake and chugging the processor quite a bit. 50% of your battery burn is the Android OS so maybe it's doing updates/indexing in the background. I've seen a few high periods like that on my S7 as well early on but it subsides. Keep us updates in the next few days to see if it normalizes.
    03-03-2016 04:08 PM
  19. LeoRex's Avatar
    Reading about Doze here - Inside Marshmallow: What is Doze, how do I use it and what does it do? | Android Central
    I don't see how you would ever know if it is working or not? Does Always on Display keep Doze from working?
    First off, it's on for everything except Google Play Services by default. And I read that Google told OEMs 'hands off'... the only configuration item you can touch is whether or not an app is marked as exempt.
    Some battery monitor apps like GSAM monitor it now.. but other than that, one way to tell is the idle usage. Granted, you have to leave the phone be for several hours, not exactly an easy task for someone with a new phone, but thing 'overnight on my nightstand' sort of thing. You'll see extremely low battery drains... well under 1% and hour (on my 6P, I've seen it drop to 0.2 or 0.3%/h) ... the longer it sits, the deeper that snooze, the less your battery drains away. If you look at your battery graph, you'll see a long plateau.
    Basically, if you put it on your nightstand at 11pm and don't touch it until 6am.... the battery should have only dropped a couple of points.
    It's pretty effective. My Nexus 6, between 5.1.1 and 6.0, saw Doze effectively cut that idle drain to gain enough to effectively give back what amounts to over an hour of screen on time a day. Now, it of course varied based on my usage.
    Oh, and if you root your phone, you can go in and fuss with the settings. How long it waits before it starts dozing, etc.
    xocomaox likes this.
    03-03-2016 04:21 PM
  20. perrochingon's Avatar
    I have been experiencing very similar results as you. I haven't had great battery life either. Have had the phone since Monday. Not really sure how much longer I need to wait to let things "settle" down.
    03-03-2016 04:54 PM
  21. mc4nam's Avatar
    Day 3. 14% left
    About an hour using Google navigation via 4g
    About 45 minutes of iheart radio on wifi
    Bluetooth, location, wifi always on.
    Maisoumenos likes this.
    03-03-2016 05:26 PM
  22. mc4nam's Avatar
    5 hours of screen time with 14% left
    03-03-2016 05:27 PM
  23. bhatech's Avatar
    I'm getting great SOT.. Everyone was suppose to get 7 hrs SOT ... How is this possible? /s
    03-03-2016 07:31 PM
  24. limitbreak09's Avatar
    Well... Your android system, android os, and google services gone wild.
    03-03-2016 08:43 PM
  25. bhatech's Avatar
    I'm just going to turn this into a dumb phone and get that crazy SOT then... Or I'll just enjoy the phone with all the features with still decent battery life. I'll do the second option.
    03-03-2016 09:23 PM
1,137 ... 23456 ...
  1. Replies: 10
    Last Post: 03-12-2018, 03:36 PM
  2. S7 and Google Messenger instead of Messages?
    By oceanclub in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 01:21 AM
  3. Anyone thought of leaving the V10 for the S7?
    By Knightstalker in forum LG V10
    Last Post: 03-19-2016, 10:55 PM
  4. Replies: 2
    Last Post: 03-15-2016, 02:46 PM
  5. V10 Battery - so much better than I expected.
    By Mister K in forum LG V10
    Last Post: 03-15-2016, 11:52 AM
