10-21-2016 05:00 PM
1,137 ... 3839404142 ...
tools
  1. andrew_ackley's Avatar
    This too.
    06-25-2016 08:43 PM
  2. love4speechless's Avatar
    There needs to be a fix for OS being so high and before you ask I'm on the Exynos version not snapdragon and the OS is always in the 30s or 40s
    06-25-2016 10:28 PM
  3. Andyvalver's Avatar
    I have some kind of battery bug. This is the 2nd time this has happened now. Phone on charge all night but it's only charged up to 50%. I only realise when I get to work.
    Posted via S7 edge 😍
    06-26-2016 12:29 AM
  4. ThrottleJohnny's Avatar
    Some of you guys have absolutely horrible signals.
    06-26-2016 01:02 AM
  5. pjwk81's Avatar
    Pretty sure it's the snapdragon processor.
    Mine is the European Exynos, so it's definitely not the snapdragon.
    06-26-2016 01:28 AM
  6. Almeuit's Avatar
    Mine so far this weekend since charging the other night. Phone calls / texts / hangouts.. Etc. Etc. And
    Attached Thumbnails S7 edge Battery life-1466925487660.jpg   S7 edge Battery life-1466925500199.jpg
    06-26-2016 02:18 AM
  7. Roman Akert's Avatar
    33hrs on battery, 4hrs 10mins screen on time, 2hrs 40mins Web browsing + use of camera (approx. 40 shots plus editing).
    47% battery remaining
    06-26-2016 02:22 AM
  8. pjwk81's Avatar
    What software version?
    06-26-2016 02:31 AM
  9. chanchan05's Avatar
    Interestingly getting huge differences in battery consumption between wifi, data, and no data. I know there should be power usage differences but not this big. Mobile data on my phone (June update) uses up more than 5x more power than when off, and almost 2x that of wifi.
    Based on what I found (see pics) standby time when no data is being used looks to theoretically be able to reach 100hrs. But having mobile data would only give it 20hrs standby. For some reason, I'm getting a lot more app activity. Looks like I got to delve into app settings more.
    06-26-2016 07:49 AM
  10. hishaq96's Avatar
    Why is Google services so high and battery draining quick
    Attached Thumbnails S7 edge Battery life-1466976108423.jpg   S7 edge Battery life-1466976126402.jpg
    06-26-2016 04:22 PM
  11. Joe J1's Avatar
    Because Google purposely likes the best selling android phones to not work as well as a nexus phone
    antodelg likes this.
    06-26-2016 05:08 PM
  12. Almeuit's Avatar
    I hope this is a joke. That is definitely not true.
    Aquila likes this.
    06-26-2016 07:28 PM
  13. Aquila's Avatar
    Google services can go up on low signal periods as it struggles to keep syncing up. It also reads higher as a percent when the screen is used less because it's a percent. So a low screen use day in a poor signal area has the most potential for nothing but the OS and services to be going.
    06-26-2016 08:29 PM
  14. Joe J1's Avatar
    Try changing versions of the notorious leaky google services
    06-26-2016 09:21 PM
  15. Joe J1's Avatar
    Nope not at all. I've installed different versions of google services on enough devices to know that it's constantly the source of battery issues.
    Look at this article. Google is going in direct competition of all the manufacturers. Wanting all the profits.
    slashgear com/googles-first-non-nexus-smartphone-tipped-for-2016-26445925/
    06-26-2016 09:23 PM
  16. Aquila's Avatar
    Yeah read the source, it's totally baseless. Odds are near 0% of that being true.
    06-26-2016 10:27 PM
  17. Almeuit's Avatar
    This. I also have used Google Services on all my devices (I have had many) and I leave high accuracy, Google Now cards, etc. etc. all on and do not have this huge drain.
    06-26-2016 10:30 PM
  18. aldo82's Avatar
    Do you have location history switched on? In my experience Google services is much higher with this on as the phone continually reports to Google where you are. Switch it off and Google services will drop. Although still remains relatively high if you use Google now etc
    06-27-2016 12:27 AM
  19. tshirttan408's Avatar
    Just wanted to throw in my experience, I received my replacement phone as my misses accidentally knocked my phone out of my hand over the weekend. I've downloaded most but not all the apps I originally had and have updated to the latest firmware. My battery life is noticeably better. At the moment I'm seeing less than 1% battery drain per hour compared to around 3.5% I was experiencing with similar use with my old phone. This is with minimal use but pretty much the same as originally so does show I had something wrong with my old phone.
    Now I'm not sure if I must have had a rogue app, or all my tinkering trying to improve battery life actually had the opposite effect but it's at least made me realise that it's less likely to be a firmware issue. I have disabled google backup though which I have read has a really bad effect on the battery life.
    06-27-2016 03:41 AM
  20. jeetu4444's Avatar
    Battery life has really gone down...now since few days google services is eating battery for nothing...S7 edge Battery life-screenshot_20160627-162443.jpg
    Posted via my Awesome Lumia 950 , Beautiful S7 Edge Gold or Surface pro 4
    06-27-2016 05:57 AM
  21. Almeuit's Avatar
    Battery life has really gone down...now since few days google services is eating battery for nothing...Click image for larger version.
    It's hard to judge on that little of time. Anything that happens on the phone will show with an usual high percentage due to such a short amount of time.
    06-27-2016 11:10 AM
  22. Aquila's Avatar
    Give it 12-18 hours of normal usage
    06-27-2016 12:23 PM
  23. Palladium65's Avatar
    Been sick today so turns out watching YouTube and movies on my phone for most of the day results in the screen on time being this high .
    Impressed since it was left with sync on and I did some light browsing and some instant messaging.
    No power saving mode used .
    Sent from my Galaxy S7 Edge
    06-27-2016 12:41 PM
  24. jeetu4444's Avatar
    Iam sure that battery life has suffered with many software updates..i just put screen shot to show that Google services is eating battery i donno y..same apps and same way i use my phone..
    Adding a new screen shot. From 2 day battery life to barely 12 hrs ..
    Here is new screen shot[ATTACH]null[/ATTACH]
    06-27-2016 05:50 PM
  25. chanchan05's Avatar
    Just got Greenify because a lot of people say it helps. It seems not to. I just greenified Facebook, and it's just up back and running. Pointless. Other stuff seem to get Greenified properly, but the ones that don't are Facebook, Instagram, and 9GAG.
    KPMcClave likes this.
    06-27-2016 07:06 PM
  1. Replies: 10
    Last Post: 03-12-2018, 03:36 PM
  2. S7 and Google Messenger instead of Messages?
    By oceanclub in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 01:21 AM
  3. Anyone thought of leaving the V10 for the S7?
    By Knightstalker in forum LG V10
    Last Post: 03-19-2016, 10:55 PM
  4. Replies: 2
    Last Post: 03-15-2016, 02:46 PM
  5. V10 Battery - so much better than I expected.
    By Mister K in forum LG V10
    Last Post: 03-15-2016, 11:52 AM
