10-21-2016 05:00 PM
1,137 ... 4243444546
  1. hishaq96's Avatar
    09-28-2016 01:05 AM
  2. jianrong's Avatar
    6hrs of SOT with 42% left? What brightness? And what version Snapdragon or Exynos? That sounds much better than what I'm getting. I can max out at 7 1/2hrs of SOT but it sounds like you can get almost 9.
    Auto brightness.
    My usage is mainly social apps, abit of youtube, email, light gaming and phone message.
    09-28-2016 07:36 AM
  3. Who884l5's Avatar
    You think if your having battery problems, you could try Greenify Battery app from the app Store ?
    It will put some of the app programs and all to sleep. Giving you better battery life.
    you got something using the power.
    Might be a few apps using power.
    have to gone in and turned notifications for Samsung Pay off >
    I am using greenifty, then phone is getting allot better after factory reseting. Im at 67% and 15 hours on the battery. While ot could of been the factory reset my charging habits changed too. Ill post and go into detail at the end of my day.
    09-28-2016 09:06 AM
  4. jeetu4444's Avatar
    Here is my latest Sot
    09-28-2016 09:14 PM
  5. blessedred's Avatar
    How long on?
    09-28-2016 10:30 PM
  6. jeetu4444's Avatar
    How long on?
    Around 16 hours...
    09-29-2016 09:22 AM
  7. blessedred's Avatar
    Around 16 hours...
    Snapdragon? And nice.
    09-29-2016 09:50 AM
  8. itrocks4u's Avatar
    After the last upgrade, my phone is draining battery really fast. 100% in the morning and with minimum usage already down to 10%. Should I downgrade to previous version of firmware?
    09-29-2016 02:50 PM
  9. TalkofNY26's Avatar
    I can't get less than 20-25℅ use from my Android system is this normal? I've gone through about 4 full charge cycles on this phone.
    09-29-2016 03:04 PM
  10. cardboard60's Avatar
    Didn't they say to not ger yer battery below 30% if'n ya could help it.
    09-29-2016 04:23 PM
  11. jeetu4444's Avatar
    I have exynos version...indian version hybrid dual sim
    09-29-2016 04:38 PM
  12. cardboard60's Avatar
    Makes you think..if you had to dova factory reset for it to get better.
    You must have a app , or you have made a change that effected the battery life.
    09-29-2016 04:42 PM
  13. Who884l5's Avatar
    During today's charge cycle was unlike other days gps didnt turn on at all. I have it enebled too.
    09-29-2016 04:53 PM
  14. Who884l5's Avatar
    Android system is 15% as usual too.
    09-29-2016 04:54 PM
  15. cardboard60's Avatar
    How often do you turn your phone off And and turn it back on.
    It's a good idea to do that every now and then.
    09-29-2016 05:02 PM
  16. mundo472's Avatar
    It's not the capacity monitor, but the power usage itself. A previous update caused a Google Backup battery leak. After the May or June update for example, my battery life dropped to almost half of what I used to reach. Turning off Google back up returned it to previous levels. That points to a simple OS battery bug.
    Currently, since the June to the latest update, I noticed that mobile data and WiFi is eating more battery than they used to, with either of them on causing a battery standby drain of 4% per hour, in contrast to having them off where I go to down to 1% per hour. That's a 4x increase in usage, which simple turning on of the data should cause. I could accept that on a 4G connection in a bad signal area, but the phone on standby with WiFi should not cause that much drain IMO. Since it was working correctly before an update, that again points to a software coding error on battery usage. At this point that is the more likely explanation compared to some conspiracy theory on the manufacturers are paying up the FCC to screw the customers over, especially in this day and age where customer satisfaction is paramount to sucess. It doesn't cut it anymore to just release a good product, like Sony does every year (but they still fall flat despite devices that can arguably be said to be superior to the S7 or HTC 10 in a number if ways). Customer satisfaction and brand loyalty ate big factors, and doing a battery job like you suggest is a bad way to cultivate those.
    Definitely an os issue. Ive noticed it isnt holding a 4g signal like it was bedore the update. Whennwe would load leaks on my blackberry, this would be atributable to a bad radio file. We'd dl an earlier one . Also the Android System is suddenly draining more battery than the screen.
    09-29-2016 05:34 PM
  17. blessedred's Avatar
    Oh ok
    09-29-2016 05:44 PM
  18. Who884l5's Avatar
    Some people on twitter ajd reddit are reporting that gear vr and oculus rift sent a update that broke and was constantly scanning... apparently a fix is coming.
    09-29-2016 06:20 PM
  19. cardboard60's Avatar
    When are they gonna release Nougat. Is that not gonna help us any.
    I thought it was like Oct.
    09-29-2016 07:45 PM
  20. Who884l5's Avatar
    No, a update is coming soon. They posted about it today.
    09-29-2016 08:26 PM
  21. blessedred's Avatar
    09-29-2016 10:05 PM
  22. blessedred's Avatar
    Currently my battery life. I'm on SD 820 and was mostly on WiFi with an hour of roaming data and watched about 1 1/2 hours of Netflix.
    09-29-2016 10:07 PM
  23. blessedred's Avatar
    The SOT.
    09-29-2016 10:07 PM
  24. TalkofNY26's Avatar
    My 5th battery cycle on my edge. Can't seem to get more than 3-3.5 hours SOT I have AOD turned off, all edge features off, wifi and bt scanning disabled. My Android system also seems to be unusually high. Anyone have any suggestions?
    09-29-2016 10:25 PM
  25. TalkofNY26's Avatar
    09-29-2016 10:26 PM
  1. Replies: 10
    Last Post: 03-12-2018, 03:36 PM
  2. S7 and Google Messenger instead of Messages?
    By oceanclub in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 01:21 AM
  3. Anyone thought of leaving the V10 for the S7?
    By Knightstalker in forum LG V10
    Last Post: 03-19-2016, 10:55 PM
  4. Replies: 2
    Last Post: 03-15-2016, 02:46 PM
  5. V10 Battery - so much better than I expected.
    By Mister K in forum LG V10
    Last Post: 03-15-2016, 11:52 AM
