10-21-2016 05:00 PM
1,137 ... 43444546
tools
  1. TalkofNY26's Avatar
    Usage data.
    09-29-2016 10:27 PM
  2. TalkofNY26's Avatar
    Percentages.
    09-29-2016 10:28 PM
  3. mundo472's Avatar
    Link?
    Link please?
    09-30-2016 04:28 AM
  4. mundo472's Avatar
    No, a update is coming soon. They posted about it today.
    Link please
    09-30-2016 04:29 AM
  5. jianrong's Avatar
    09-30-2016 06:35 AM
  6. blessedred's Avatar
    Total
    Clear the cache partition. It fixed mine.
    09-30-2016 08:55 AM
  7. Who884l5's Avatar
    After yesterday's cache wipe and restart my phone made a hero's recovery!
    10-01-2016 05:32 PM
  8. Who884l5's Avatar
    Yesterday i was at 15% at 3 hours just for a reference.
    10-01-2016 05:35 PM
  9. hishaq96's Avatar
    https://uploads.tapatalk-cdn.com/2016...0f4beb266a.jpghttps://uploads.tapatalk-cdn.com/2016...43327fcddf.jpg
    I wiped the cache many times and still cannot get the battery life you are getting. When it goes to 60% I just about be at 2hrs SOT or less. How do you get that battery life?
    10-01-2016 06:59 PM
  10. Who884l5's Avatar
    I also did a factory reset too. If gear vr is at the top of android system you should try to clear its chache and restart. My android system drain either fixed itself or clearn gear vr's chache did it for me. I was having terrible drain until recently. Im not sure if the factory reset did it or if i got some update.
    10-01-2016 08:01 PM
  11. Who884l5's Avatar
    Sepembers update initially caused drain. This doesnt even compare to the usage i use to get. But its much better.
    10-01-2016 08:04 PM
  12. Morty2264's Avatar
    You know, I'm thinking of maybe picking this phone up in a few months (okay, maybe nine months - if my phone holds up!) ; so knowing that the battery life is this good is awesome!
    10-01-2016 08:06 PM
  13. Who884l5's Avatar
    It is really good. If i didnt touch it so much i could easily get 2 days out of it.
    Morty2264 and KPMcClave like this.
    10-01-2016 10:28 PM
  14. jianrong's Avatar
    49÷. Android System 10÷.
    10-02-2016 06:40 PM
  15. Morty2264's Avatar
    This is awesome! Thank you for letting me know! Looks like this phone will be a solid contender come Upgrade Time!
    10-02-2016 08:58 PM
  16. bIOforger's Avatar
    How is this an accurate gauge of your batt life, you can clearly see you charged it again on the 10/2!
    10-07-2016 07:24 AM
  17. clintw22's Avatar
    In two and a half days, one charge from about 50% to 90% isn't bad. It depends on SOT. If OP let it sit, then it's not very good. But if he used it alot, id call it pretty good.
    10-07-2016 09:31 AM
  18. blessedred's Avatar
    This is on WiFi yesterday. I could've gotten over 8 if I didn't fall asleep watching Twitch.tv lol S7 edge Battery life-423.jpg
    10-09-2016 02:32 PM
  19. blessedred's Avatar
    10-09-2016 02:32 PM
  20. Shawn0813's Avatar
    Can someone help me with my battery life, right now I'm only getting about 3 hours sot. I have gone through and disabled stuff but still horrible battery life.
    10-10-2016 08:01 PM
  21. mundo472's Avatar
    Check the forums. Delete Occlus and disable gear Vr (have to do it every time you reboot, too). Seems to be tied to androids latest update. I think it's got a bad radio too. Hoping for October update soon
    10-11-2016 07:45 PM
  22. cardboard60's Avatar
    If you just got a S7E you need to charge and use it for a few weeks before it gets better.
    Look to see what is using the most of your battery also.
    It will tell you.
    Have you gone to a Best Buy and talked to a Samsung Rep on the battery life also.
    10-11-2016 07:57 PM
  23. cardboard60's Avatar
    10-11-2016 08:00 PM
  24. Palladium65's Avatar
    Anyone experience their s7 edge getting really hot and battery life eating away fast after they updated the Google photos app recently ?
    10-13-2016 12:38 PM
  25. hishaq96's Avatar
    I have factory reset the phone yesterday and still the battery is draining away
    10-13-2016 12:53 PM
1,137 ... 43444546
  1. Replies: 10
    Last Post: 03-12-2018, 03:36 PM
  2. S7 and Google Messenger instead of Messages?
    By oceanclub in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 01:21 AM
  3. Anyone thought of leaving the V10 for the S7?
    By Knightstalker in forum LG V10
    Last Post: 03-19-2016, 10:55 PM
  4. Replies: 2
    Last Post: 03-15-2016, 02:46 PM
  5. V10 Battery - so much better than I expected.
    By Mister K in forum LG V10
    Last Post: 03-15-2016, 11:52 AM
