10-21-2016 05:00 PM
1,137 ... 444546
tools
  1. cjtkd's Avatar
    Glad I found this thread! I got my S7 Edge last Friday from 02 in the UK. Less than impressed by the battery life (having come from a rock solid Note 4). I was ready to send the device back as faulty when I stumbled upon this thread. I'm guessing my results are about average for what others are getting IE a gradual if constant drain?
    10-21-2016 08:32 AM
  2. optimummind's Avatar
    Looks normal for the first 7% drain. Do you have stats for at the end of the day?
    10-21-2016 08:37 AM
  3. cjtkd's Avatar
    A little later in the day. Bit of browsing and a short trip using google maps.
    Attachment 243074
    Attachment 243075
    Attachment 243076
    10-21-2016 08:38 AM
  4. cjtkd's Avatar
    10-21-2016 08:50 AM
  5. cardboard60's Avatar
    How many has gone in and optimize their battery
    10-21-2016 09:50 AM
  6. Nakrohtap's Avatar
    Judging by your Facebook notifications, I would start there with Facebook being a factor.
    chanchan05 likes this.
    10-21-2016 10:09 AM
  7. cardboard60's Avatar
    Go alson into notifications.
    There may be a lot of apps you don't use
    Or bloatware ,turn a lot of the notifications off. I even turn off email notification, I go to email and swipe down on the screen to get it to check for email.
    Only notification I leavever on are system and text messaging
    Your apps will constantly run and check for updates.
    This uses up battery.
    10-21-2016 10:52 AM
  8. Google10's Avatar
    Lol I thought the same thing
    10-21-2016 12:41 PM
  9. cjtkd's Avatar
    Usually I would agree, however this was just a lot of replies to a post that came through at once. That said, it was never an issue working like this on my note 4, a two year old device, so really I shouldn't have to change the way I use a brand new handset.
    10-21-2016 01:50 PM
  10. cjtkd's Avatar
    10-21-2016 04:58 PM
  11. cjtkd's Avatar
    10-21-2016 04:59 PM
  12. cjtkd's Avatar
    10-21-2016 05:00 PM
1,137 ... 444546
  1. Replies: 10
    Last Post: 03-12-2018, 03:36 PM
  2. S7 and Google Messenger instead of Messages?
    By oceanclub in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 01:21 AM
  3. Anyone thought of leaving the V10 for the S7?
    By Knightstalker in forum LG V10
    Last Post: 03-19-2016, 10:55 PM
  4. Replies: 2
    Last Post: 03-15-2016, 02:46 PM
  5. V10 Battery - so much better than I expected.
    By Mister K in forum LG V10
    Last Post: 03-15-2016, 11:52 AM
