ClintRo
Trusted Member
Re: S7 edge Battery life is very good
I wouldn't be surprised if it was indexing them all and using a lot of resources. I bet after it is done you would see a drop back to normal.... Maybe remount it before bed and hook to charger over night and see how it does the next day.
So, since I got my edge, the battery life Seemed terrible and it was always super hot when using it. I checked battery usage and "media" was unbelievable high for battery usage, even immediately after unplugging the phone from charger. Decided to unmount my SD card and it stopped the issue. Any thoughts? Must be Something bad on my sd card? The SD card has all of my photos, videos and about 8,000 songs that I was using in my S5 and just popped into the edge. Thanks for any help.
