How to I bring that screen use details screen up?
Just click on it...simple
Posted via my Awesome Lumia 950 , Beautiful S7 Edge Gold or Surface pro 4
Well I noticed that if i try to get a lot of stand by time for the phone,then I won't get good on screen time. For the past 8 hours I have used the phone a lot, not much stand by. So far SOT is 5h24m and have 38% left.
When the phone is mostly idle and only casual use i get about 3-4h SOT and stand by of 24-35h overall time before battery dies on me.
Well, it's kind of simple. If you use it non stop, you're devoting all of the battery life to what you're currently doing therefore 100% of battery is devoted to keeping the screen on and doing whatever else you're doing. If you use it throughout the day, only part of the power is being devoted to the screen. Standby still requires battery life. You've got to power the radios and all that. So depending on how much standby we're talking, maybe only like 50% of the battery is going towards the screen and the other 50 is going to standby. So the screen can no longer stay on as long because of the reduction of battery power. This is an oversimplification, but you get the point. That's why it happens like that.I have noticed this as well.
Does anyone have a scientific answer for it?
For example, if I'm just casually texting people throughout the day I have significantly less SoT versus using the phone heavily non-stop; however I get more standby time.
So does leaving the screen on all day use less power than the phone constantly being waken up and put back to sleep?
Maybe I should not be worrying too much about SoT if I get 24-48 standby time?
From yesterday. Very happy with this, coming from an S5 where I could get about 4hours SOT
This is my battery life today:
//uploads.tapatalk-cdn.com/20160502/bde3719d1da7404d178b6f4d01496558.jpg
Screen on time:
//uploads.tapatalk-cdn.com/20160502/1021ee6ebc22c9ea98699b0399ce5b4f.jpg
I think that's good?
40-50% with the auto box checked.What screen brightness do you use? To get that much screen on but have it appear at the top of the list makes me think you must run it pretty dull?
Does battery last longer if you use auto Is auto better? Is that what most people use? I usually just turn mine up and down depending on what I am doing. My old M9 I kept on auto alot.
I tend to use auto because I can't be bothered to change it in the sun.Does battery last longer if you use auto Is auto better? Is that what most people use? I usually just turn mine up and down depending on what I am doing. My old M9 I kept on auto alot.
