How do you turn off the percentage for the battery?
Do you have data always on or not? I get 5hrs SOT too, but only on 15-16hrs standby. Data (4G) or WiFi always connected. I could lower consumption down to 0.7% per hour on standby, but that means turning off data or WiFi. As it is I get around 3-5% per hour when either connection ie active.I forgot to so a screen shot of my battery stats, but as of recently, my battery has gotten better. I've had over 5 hours of SOT and about 21 or so hours of standby ... this is better than its been for the past couple of months and I suppose package disabler pro has done the trick to fixing whatever issue I was having before. I am hoping it stay this way and even improves!
I miss the old auto data toggler apps.
I meant the apps like GreenPower which automatically turns off data when the screen is off and on when the screen is active, and let's it turn on at set intervals throughout the day.I used to use NFC tags for that on my old LG, one at home, one at work, one on the dash of the car that toggled data/wifi/bluetooth/sound/etc as needed. This phone makes it less necessary though.
Even after the OS update and factory reset, it's back as bad as ever. Sick of it now, phone has to go.
http://i63.tinypic.com/2us8pdf.png
Isn't there an option in the wifi advanced setup to keep wifi on during sleep? Can be set to always, while charging, never.I meant the apps like GreenPower which automatically turns off data when the screen is off and on when the screen is active, and let's it turn on at set intervals throughout the day.
That's wifi. Doesn't do anything about mobile data.Isn't there an option in the wifi advanced setup to keep wifi on during sleep? Can be set to always, while charging, never.
Maybe it's my background apps. I got a number of Tasker profiles polling for events. And Lightflow is showing up pretty high on GSAM lately, about 4th or 5th when before it didn't even appear. Oh well. The price of convenience. Lol.Yes I always have data on
Yesterday I managed to get my best battery life ever so far, I'm very pleased !
View attachment 230478 View attachment 230479
