MclBR
I had just disabled the WiFi and Bluetooth Auto Search. Do you guys think it'll make a good difference on battery life? I'll recharge my phone and let you guys know about the results tomorrow. Thanks.
Could you guys give me a help?
I bought, yesterday, a Galaxy S7 Edge equipped with an Exynios (Version GM-9350F).
With normal usage - WhatsApp, spotify, Ytb and games sometimes - I got a SOT of 5 hours... Screen brighteness is set in medium-autobrighteness, and I'm using most of the time Wifi and sometimes LTE/3G.
I've seen some people saying that they got 7hours of SOT, so I was wonder: Is my SOT normal? Do I have a deffective phone?
Big thanks in advance!
I suspect that your usage is close to the norm. I share office space with several folks who have this phone, and we all tend to get around 5 hours screen on time with varying usage.
I keep the WiFi autoscan disabled because the only WiFi that I use is my own. Everything else is on the mobile network.
My battery life was OK but not great for the first few cycles, but then got a lot better very quickly. It's a big battery, so I was still able to comfortably make it through the day. I normally let a new battery drain to about 10% (with battery saving modes temporarily turned off) before recharging, and I do it for about a week. I don't know how important it is to "condition" these newer batteries, but I got started doing that a long time ago.
Of course, part of the added battery drain with a new device is exploring the new device. It seems to take me about a week or so to stop tweaking the phone or to get past the "wow, this is cool" stage and leave the phone alone unless I'm actually using it.
Remember that it can take a good week or so for a battery to settle. Now that you're past the first week "gee whiz" stage with the phone, run your test a few more times and see if it starts to get better. My power drain dropped substantially after the first week, when I was no longer tweaking it all day long or loading and configuring apps.
blessedred - not likely!, I've found no issues with battery life and literally minutes after that patch arriving my two sims actually started to work, which they hadn't done since I first got the phone 2 month previously - that patch actually saved my sanity
I bought the S7 Edge because of the large battery capacity, but have suddenly suffered a severe battery drain issue so searched high and low for a solution.
Everywhere you look there are examples of people having issues and endless advice as to how to maximise life, usually in the form of 'turn your excellent smart phone into a very poor dumb one'. However, I have had a thought which I'd like to share.
Perhaps this apparent fast running, battery draining phone and the variation in peoples' experience has the one root cause and it is nothing other than poor battery manufacture. The capacity should be 3600mAh, but how do we know? How do we know when we buy it and how do we know six months later? We only have the spec to go from. If the battery is of a poor quality it may well be that only a proportion are genuinely the full capacity and many will fail too soon.
Maybe the Note 7 debacle is just a more obvious consequence!
Clearly, there is something wrong when you have a battery read out which shows a combined use of about 360mAh and a gauge that indicates 56% left, which is where mine is at now. Mathematically, I've used 10%, or I've only got a maximum capacity of about 650mAh. Hmmm....
Are so many of these threads that suggest battery saving routines simply missing the point that Samsung (and other companies too) are skimping in the battery?
It's not the capacity monitor, but the power usage itself. A previous update caused a Google Backup battery leak. After the May or June update for example, my battery life dropped to almost half of what I used to reach. Turning off Google back up returned it to previous levels. That points to a simple OS battery bug.Perhaps, in some instances, the updates affect the capacity monitor, but I'm not aware of how that might interact with the operation which I would've thought only depended on available voltage.
That said, I just have a niggling feeling that for so many people to suffer such a wide variety of issues it seems unlikely to be down to the OS. If it was then you would see a good number of successful solutions.
