No, a update is coming soon. They posted about it today.
I wiped the cache many times and still cannot get the battery life you are getting. When it goes to 60% I just about be at 2hrs SOT or less. How do you get that battery life?After yesterday's cache wipe and restart my phone made a hero's recovery!
//uploads.tapatalk-cdn.com/20161001/b123658229a4d721d35c800f4beb266a.jpg//uploads.tapatalk-cdn.com/20161001/0ec619c1b2c9d7a8e9abd943327fcddf.jpg
I also did a factory reset too. If gear vr is at the top of android system you should try to clear its chache and restart. My android system drain either fixed itself or clearn gear vr's chache did it for me. I was having terrible drain until recently. Im not sure if the factory reset did it or if i got some update.I wiped the cache many times and still cannot get the battery life you are getting. When it goes to 60% I just about be at 2hrs SOT or less. How do you get that battery life?
It is really good. If i didnt touch it so much i could easily get 2 days out of it.You know, I'm thinking of maybe picking this phone up in a few months (okay, maybe nine months - if my phone holds up!) ; so knowing that the battery life is this good is awesome!
How is this an accurate gauge of your batt life, you can clearly see you charged it again on the 10/2!
