03-10-2017 08:18 PM
45 12
tools
  1. clsdv's Avatar
    I'm getting allot of noise/static when connected to my car stereo via AUX cable. I didn't have this issue with my S6. Any solutions?
    Edit: Tried two S7 Edges and two different AUX cables. Still the same.
    AlexFirth91 likes this.
    03-02-2016 01:43 AM
  2. AlexFirth91's Avatar
    I have noticed a similar issue when charging my phone, it hit my aux cord at my office and the speaker made static from the charging cable. I think the S7 Edge conducts electromagnetic force fields of some sort lol when its charging. Super Weird! But thank the metal and serious amount of lithium ion. Just my guess, not a science major.
    03-02-2016 02:20 AM
  3. clsdv's Avatar
    I'm not sure what's causing it but I do need a solution. I don't want to send it in either since it's happening with both phones.
    03-02-2016 04:19 AM
  4. jaltman's Avatar
    Consider the possibility its your cables. How long are they? Is there an increase in noise if you wiggle the connector? If the cable is short enough, try wrapping it in aluminum foil to see if that makes a difference. If it does, then its a poorly shielded cable..
    03-02-2016 07:39 AM
  5. clsdv's Avatar
    One cable is 3 feet the other is 6. Both cables are new and no difference is made when wiggled. I'll try the foil paper out.
    03-02-2016 11:14 AM
  6. peeps777's Avatar
    I bought 2 galaxy s7 edge and i'm having the same problem on both. I've tried 2 different cables and it does the same with both. Lots of static, without connecting it to the charger.
    03-12-2016 01:05 PM
  7. clsdv's Avatar
    I found a solution. Go to settings, sounds, sound quality, connect your AUX and enable UHQ upscaler
    03-12-2016 02:27 PM
  8. b dc's Avatar
    Hey CLSDV, I received my s7 from the pre-order and I had the same issue. It literally drove me CRAZY! I actually ended up exchanging the phone. I really hope your advice works, I'll have to try it tomorrow morning
    03-13-2016 12:59 AM
  9. Kasper610's Avatar
    I tried the UHQ thing and I can hear music now, but if I pause or switch songs or albums, all I hear is loud static! It's driving me absolutely insane! There is no way I will stay with this phone if this is how it's gonna be. Think im returning it and waiting for the G5.
    03-13-2016 10:43 AM
  10. b dc's Avatar
    Could it be a software issue with marshmallow? Im out of exchanges with ATT.... so i will have to contact Samsung next.
    03-13-2016 02:19 PM
  11. b dc's Avatar
    Im on the phone right now with Samsung support about the issue right and will report back briefly...
    03-13-2016 02:45 PM
  12. TMavC5's Avatar
    Time to move on and stop using AUX cable. Try using this instead.
    http://www.amazon.com/gp/product/B00MJMV0GU?psc=1&redirect=true&ref_=ox_sc_act_title_2&smid=A1E57UY6AMKO25
    blambtn likes this.
    03-13-2016 02:47 PM
  13. Kasper610's Avatar
    I really don't wanna return it and wait for a G5 but if this is gonna be the case, I can't do this with this phone.....
    03-13-2016 03:11 PM
  14. b dc's Avatar
    I just got off the phone with Samsung support, and I'm gunna have to send it in for "warranty repair service" I really hope they get to the bottom of this issue. I love the S7 but its audio complications are straining our relationships together ;p
    03-13-2016 03:14 PM
  15. Kasper610's Avatar
    There ain't no way I'm sending in a brand new phone only to receive a refurbished one right off the bat.... Negative! Looks I'll be pre-ordering a G5.....
    03-13-2016 03:44 PM
  16. b dc's Avatar
    I asked about that and you definitely dont get a refurbished one back. They repair what you sent them.
    03-13-2016 04:07 PM
  17. b dc's Avatar
    This ain't the joke they call "mobile insurance" ......such a scam
    03-13-2016 05:59 PM
  18. Kasper610's Avatar
    Anyone find any answers on this yet?
    03-14-2016 04:37 PM
  19. b dc's Avatar
    Im going to aquire a USB OTG cable today and see if I can play audio via the micro usb charging port. I'm still very much engaged in troubleshooting due to my hobby of enjoying high quality audio. I did get a cheap ground loop isolator which did quiet it down a bit but my s3 never had a problem with my car stereo, so that cant be the correct solution... I do have the option of returning my s7 and going back to my s3 or going with the only other comparable phone out there in specs,which is the LG G5, which doesnt do it for me like samsung. DONT PUT THIS EVIL ON ME RICKY BOBBY! btw this is the ground loop isolater which does work to an extent http://www.amazon.com/Mpow-Ground-Is...cUvbUpU5062598
    minoch likes this.
    03-15-2016 02:16 PM
  20. recDNA's Avatar
    So Bluetooth is too soft and Aux has static? This doesn't sound good.
    03-15-2016 02:24 PM
  21. rvgraham's Avatar
    Just to chime in with additional data. I use an Aux cable to headphone jack into stock 2003 BMW 530i stereo with the "DSP" package. No issues at all. Haven't tried connecting the charger at the same time, that used to cause issues with my S6. (Probably a multiple paths to ground issue or something along those lines.)
    Bob
    03-15-2016 02:49 PM
  22. dpham00's Avatar
    No problems with Bluetooth in my car...
    03-15-2016 02:52 PM
  23. recDNA's Avatar
    Some people complained it wasn't loud enough. Glad yours is good.
    03-15-2016 04:41 PM
  24. johnny8410's Avatar
    I just paired mine today with my car and it works good. Didn't notice any difference from my S6 edge.
    03-15-2016 08:20 PM
  25. recDNA's Avatar
    Is Bluetooth as loud as radio?
    03-15-2016 08:21 PM
45 12
  1. Will Samsung Galaxy S7 work with Straight talk sim card?
    Last Post: 03-07-2018, 02:27 PM
  2. S7 edge Battery life
    By limitbreak09 in forum Samsung Galaxy S7 edge
    Last Post: 10-21-2016, 06:00 PM
  3. How do I unlock a Samsung Galaxy S6 Edge Plus screen?
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 04-11-2016, 05:50 AM
  4. Why can't I start my Google Account?
    By AC Question in forum Misc. Android Phones
    Last Post: 03-02-2016, 10:43 PM
  5. Upgrading from the S5 to the S7 Edge
    By RJLOMMD in forum Samsung Galaxy S7 edge
    Last Post: 03-02-2016, 03:08 PM
