1. EMGSM's Avatar
    When ever I go into a game, the screen goes into saturation mode. This happens even if I put the display on basic mode. As soon as I leave the game it automatically goes back to normal. Has anyone else experienced this?
    03-02-2016 09:37 AM
  2. TommyC1969's Avatar
    I don't have my GS7E yet (it is being delivered today), but my bet is that it is working as designed. I'm betting that Samsung assumes people to have the best visual experience when playing a game so the phone automatically switches into saturation mode when the game starts, and then reverts back automatically to whatever you had it set at before when you're done.
    Having said that...it could also be a bug.
    EMGSM and johmar228 like this.
    03-02-2016 11:56 AM
  3. johmar228's Avatar
    You're not the only one. I've expended this last 3 days trying to figure it out, and I think I found the solution. (Need computer for this)
    On your phone go to:
    About device> Press several times on Build number (to activate Developer options)> go back to settings> turn on Developer options> turn on USB debugging.
    On your computer:
    Download and install:
    Downloads for Mac:
    Debloater.v.x.xx.dmg
    Android.zip
    Downloads for Windows:
    Debloater.v.x.xx.exe
    ADB for Windows
    Install the app and drives, plug in your phone> open debloater> click read device (top left button)> click filter> type this in: GameOptimizer.apk> check it> click apply!
    And since I did this I Can play normally on my S7, without that annoying over saturation.
    03-07-2016 11:42 PM
  4. madgalaxy's Avatar
    Just got my S7 Edge today and it does the same when playing games. I do not like it cause I prefer my screen at "AMOLED Photo".
    03-08-2016 02:49 PM
  5. gringoaplatanado's Avatar
    So the solution is to disable the fancy Samsung game optimizer?? LOL Sucks that it came down to that, have you tried package disabler from the play store? Does all of that without having to connect to a computer...wondering if it works ok on the S7E (mines on the way today so still haven't had a chance to play yet.)
    As a side note, I found it hilarious that the solution proposed wasn't to outright say "hey...need to disable the optimizer" rather the steps were outlined in detail as to how to disable it LOL.
    03-08-2016 03:12 PM
  6. madgalaxy's Avatar
    I just tried Package Disabler from the play store and disabled "Game Service (com.enhance.gameservice) and it worked. No more oversaturation on games!
    03-08-2016 03:25 PM
  7. Adiliyo's Avatar
    are there no settings for the game optimizer that can be adjusted?
    03-08-2016 03:49 PM
  8. Jose Fossatti's Avatar
    Hi have you tried NFS No Limits with disabled "Game Service (com.enhance.gameservice) ? MInes does not work with this...
    05-17-2016 05:07 PM
  9. chanchan05's Avatar
    Doesn't happen to me, but I adjusted game tools to set the power saving game mode. I'm playing just CoC and CR and BB, all by Supercell. Those things don't need 60fps and all the power.
    05-17-2016 07:57 PM
  10. Jose Fossatti's Avatar
    thanks seem to be in some games, i think i'll sell this crappy exynos S7Edge... so sad samsung
    05-18-2016 08:21 AM
  11. chanchan05's Avatar
    It's personal preference I guess. Personally I love the bright colors. Maybe that's why I don't notice it as much.
    05-18-2016 09:03 AM
  12. itsnotmeitsyou's Avatar
    You guys need to download the app "Game Tuner" by Samsung. You can change the brightness, quality, and contrast of games individually.
    05-18-2016 07:07 PM
  1. Who is using their S7 Edge without screen protection????
    By BIG CAT 7 in forum Samsung Galaxy S7 edge
    Last Post: 07-15-2017, 09:29 AM
  2. LG G4 Won't Turn On - Can I Get Photos?
    By AC Question in forum LG G4
    Last Post: 01-12-2017, 03:02 PM
  3. What can be done to have the charging port fixed in my Galaxy S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-03-2016, 01:12 PM
  4. why my phone rebooting when wifi/mobile data is on?
    Last Post: 03-02-2016, 09:25 AM
  5. Replies: 1
    Last Post: 03-02-2016, 09:06 AM
