1. Mason Sell's Avatar
    I know that with Now on Tap you would normally press and hold the home button on the on-screen buttons. Since the Galaxy S7 and S7 Edge have physical home buttons, how do you use Now on Tap? I am excited to get my S7 Edge, but I have no idea what the deal is with Now on Tap. Anyone know what's the deal?
    03-02-2016 07:00 PM
  2. pshows's Avatar
    If you hold down the home button it will activate the google now on tap feature
    03-02-2016 07:03 PM
  3. PsychDoc's Avatar
    Same thing, just long press the home button.
    03-02-2016 07:04 PM
  4. Mason Sell's Avatar
    Isn't that how Google Now launches? That's how it works on the S6 at least. Is it just purely contextual?
    03-02-2016 07:07 PM
  5. bhatech's Avatar
    Works the same way .. Hold down home button and brings up now on tap. See screenshot from my s7 edge. If you click the G icon in the bottom it will bring up Google now.
    03-02-2016 07:17 PM
  6. Mason Sell's Avatar
    Oh, niceeeee. I cannot wait to get mine. I am upgrading through Jump On Demand though so I have to wait until it comes out. How is day-to-day use regarding battery life and just generally living with the edge display?
    03-02-2016 10:48 PM
  7. bhatech's Avatar
    It's fine no complains, battery life gets thru the work day and I'm not one of those guys getting 6-7 hours SOT lol. I keep all settings turned on, push emails, apps sync, connected to gear S2, always on display turned on. With all those still gets thru work day and may have to reach for the charge around 8 to 9 PM. Obviously everyone's usage, apps, set up, network is different and battery life won't be same. All I can say is battery life is not a concern for this device.
    As far as the edge features, I don't use them much though the night clock is cool ... I got the edge over S7 just for the bigger battery size. Some frustration with the edge is in constantly triggering some touch targets on the screen because there is no easy way to hold the phone.
    03-02-2016 10:57 PM
  8. Mason Sell's Avatar
    Yeah it sounds like you're quite the power user. The galaxy s6 would have to be charged 3 times to maybe make it to the night haha. I could probably get 2 days out of this phone.
    I was a little concerned that it would be easy to accidently tap things due to the edge. Don't really expect to use the edge features much either (though some of them are cool), but the battery size is a huge draw for me. I like the regular S7, though due to the battery size, I am doubting the battery life will be as good as the s7 edge
    03-02-2016 11:05 PM
  9. Alfred Yeap's Avatar
    Press and hold HOME key always launch Google Now and never Now on tap. I have no idea how to enable it?
    04-05-2016 02:55 AM
  10. CrypticDweller's Avatar
    Go into the Google Now settings, and enable Now on Tap. It's off by default, and long press home just brings up Google Now. After enabling Now on Tap, it works fine.
    04-05-2016 11:24 AM
  11. Jaycemiskel's Avatar
    It was on by default for me. I personally don't find it that useful, but I haven't turned it off.
    04-05-2016 02:07 PM
  12. andya1942's Avatar
    I lost my audio"ding" in OK Google and after searching all day it came back on after I launched Google now cards.
    04-28-2016 05:30 PM
  13. jono91702's Avatar
    You must enable Now on Tap in the Google application settings. Then long press the home button and it will work.
    06-09-2016 02:56 PM
  14. ChiefJaguar's Avatar
    Just to be clear, this is only available on Marshmallow right?
    06-13-2016 09:35 PM
  15. aldo82's Avatar
    Yes and you can't get an s7 edge with anything other than marshmallow
    06-14-2016 05:23 AM
  1. What kind of Micro SD cards are compatible with my S5 active?
    By renza86 in forum Samsung Galaxy S5 Active
    Last Post: 08-04-2016, 03:14 PM
  2. Swapping Motherboards on Galaxy S4 to Retrieve Data?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 03-02-2016, 08:23 PM
  3. How can I use a usb 2.0 microscope on a Android 5.0 tablet?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 03-02-2016, 08:22 PM
  4. How do I transfer photos to my sd card on a Galaxy Note 3?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 03-02-2016, 08:21 PM
  5. How do I bock a number from texting me on my LG?
    By AC Question in forum LG Android Phones
    Last Post: 03-02-2016, 08:19 PM
