1. Cakefish's Avatar
    Can someone please check whether you can disable device encryption on the S7s please?
    This is how you should be able to do it if it's possible; How to disable encryption in Android Lollipop | Android Central
    03-02-2016 08:11 PM
  2. xocomaox's Avatar
    I assumed it came from the factory unencrypted?
    03-02-2016 08:40 PM
  3. vr002sh's Avatar
    I have the T-Mobile variant. There is an option to encrypt the SD card (assume it's un-encrypted by default). But no option to decrypt internal storage. With Marshmallow, the default was to encrypt internal storage, some manufactures do give an option to decrypt, but looks like Sammy did not.
    03-02-2016 09:48 PM
  1. Why does Google maps take forever to reroute?
    Last Post: 05-01-2016, 08:46 PM
  2. *****'s guide to customizing watch faces?
    By wenglish#AC in forum ASUS ZenWatch 2
    Last Post: 04-28-2016, 05:15 PM
  3. What security update are on Unlocked International phones
    By torbach1 in forum Samsung Galaxy S6 edge+
    Last Post: 03-07-2016, 03:38 AM
  4. regarding unlocking phone using face recognition
    By Michael Lento in forum Ask a Question
    Last Post: 03-02-2016, 08:24 PM
  5. How do I find out a broken phones carrier?
    Last Post: 03-02-2016, 08:07 PM
