anon(5719825)
Retired Moderator
I'm still trying to find a stable root process for my Note 5. I've tried two of the different kernels out there and both of them cause my Note 5 to randomly reboot, especially during phone calls.
Friday night, I decided to try a custom ROM to see if I would have better luck. Nope. It's only been about six hours since I installed that ROM and my phone rebooted once on it's own already.
I never had this problem with rooting my Note 4 and Note Edge.
I root my phones mostly so I can block ads system wide including ads in apps. I know Adguard does this without root but then it installs an icon in the status bar that you can't get rid of plus a card that never goes away in the notification pane. I'm willing to put up with that for a stable phone that does not reboot during a phone call.
I won't even consider rooting my S7 Edge for a very long time after this, if ever.
