03-10-2016 11:26 AM
283 ... 101112
tools
  1. GNawaz's Avatar
    yes i pre-order my s7 edges on 5th and got it early on 8th march yesterday with free VR From sumsung uk official website. it is really great mobile so smooth
    03-09-2016 08:48 AM
  2. trekmatt's Avatar
    Picked up my VR headset today so will try to give it a try out soon, looking forward to it
    03-09-2016 11:07 AM
  3. trekmatt's Avatar
    Has anyone left the plastic on the front of their phone that it came with? I've so far left mine on instead of trying to put another protector on but not sure whether it's ok to leave it on or if it should be removed
    03-10-2016 06:50 AM
  4. Cakefish's Avatar
    I did for a day, them I replaced it with a proper screen protector which ended up being worse. Keep it on if it doesn't bother you I found the little tab at the top noticeable though.
    03-10-2016 06:55 AM
  5. trekmatt's Avatar
    Yea I've just put my case on and the little tab has lifted a little bit but doesn't seem too bad really atm, might take it off totally eventually anyway as I've put mine into a flip case. Have u downloaded the software update today btw? Seems to get rid of Samsung pay
    03-10-2016 07:15 AM
  6. ninjakel's Avatar
    Mine has arrived today, still at work til 5 though. I've got a zagg HD screen protector waiting for it which will go on immediately.
    03-10-2016 07:52 AM
  7. Cakefish's Avatar
    Yep, with the same result.
    03-10-2016 09:05 AM
  8. trekmatt's Avatar
    Obviously we're not gonna get that anytime soon then if they needed to remove it lol
    03-10-2016 11:26 AM
283 ... 101112
  1. What's the best way to transfer content to my S7 Edge from my S5?
    By RJLOMMD in forum Samsung Galaxy S7 edge
    Last Post: 01-27-2017, 12:31 AM
  2. S7 Battery Life vs. Note 5
    By henryfool3 in forum Samsung Galaxy S7
    Last Post: 03-03-2016, 11:50 AM
  3. Replies: 0
    Last Post: 03-03-2016, 11:15 AM
  4. Good Battery Life Review S7 Edge
    By jimbo1mcm in forum Samsung Galaxy S7
    Last Post: 03-03-2016, 10:55 AM
