1. itguyjax8430's Avatar
    Apparently Samsung didn't tell people that you can install apps to the SD card. Can anyone confirm this works on their phones?
    Once the app is installed go to settings, apps, and find an app and see if it lets you move the storage location.
    Forbes Article Discussing it
    http://www.forbes.com/sites/gordonke.../#487c770b1757
    03-04-2016 02:54 PM
  2. SteveISU's Avatar
    That's an Android thing I believe, not a samsung thing. Think it was around 4.0 Ice Cream Sandwich.
    03-04-2016 02:57 PM
  3. Kevin OQuinn's Avatar
    Well, SD card stuff has changed a LOT since ICS.
    I believe I have seen people post screenshots of the S7 letting them move apps to the SD card. They will not install directly to the SD card, but after the fact some can be moved.
    03-04-2016 02:59 PM
  4. Jaycemiskel's Avatar
    We've been able to move apps in Android for a while. That's not really anything special. I wish they had just given us an option for more space because not all apps can be moved or only a portion of it can be.
    pearly86 likes this.
    03-04-2016 05:02 PM
  5. mc4nam's Avatar
    I just tested. I moved an app and moved it back without any problems.
    SR45 and Kevin OQuinn like this.
    03-04-2016 05:14 PM
  6. kpreachers's Avatar
    I've been able to do that on my S5 for a year now. I just hope the fix the issue that if the app updates, it stays on the card and doesn't have to be moved back from the device to the SD card. I would be happy if that was the case.
    Batradia and Shoesmom like this.
    03-04-2016 08:56 PM
  7. Kevin OQuinn's Avatar
    On your S5 it was a Samsung built feature (since Google didn't support SD cards in lollipop). On the S7 it's most likely Google that built it and not Samsung.
    Hopefully that means it has fewer bugs.
    03-05-2016 01:55 AM
  8. pearly86's Avatar
    The updates are the problem. I've been putting apps on my sd card for years (still have my galaxy s4), but when the apps update, they move back to the device storage. I then move them back to sd.
    Batradia likes this.
    03-05-2016 02:01 AM
  9. Gator352's Avatar
    Read an article on play newsstand that samsung IS letting users install all apps to the sd card. If you remove the card, the icons for the apps on the phone will become greyed out till the card is inserted again. You can also remove and insert the sd card without turning off the phone as well.
    78standards likes this.
    03-05-2016 10:46 AM
  10. Jaycemiskel's Avatar
    If that's true, then I'll be satisfied. I mean I got the phone anyway, but that was the only thing I didn't like about it. I just think the VR stuff will take up a lot of space
    03-05-2016 01:42 PM
  11. Kelt67's Avatar
    I've not been able to move ANY VR apps to the SD card on the S7 but other apps move just fine. I've emailed Samsung about it this morning.
    03-07-2016 09:57 AM
  12. Shoesmom's Avatar
    Can anyone verify if the issue with apps moving back to the internal memory from the SD card after updates has been fixed on the S7?
    03-29-2016 07:17 PM
  1. How can I tell if Doze is working on my Samsung Galaxy S7 Edge?
    By janderson1271 in forum Samsung Galaxy S7 edge
    Last Post: 03-08-2016, 07:21 AM
  2. Replies: 1
    Last Post: 03-07-2016, 06:10 PM
  3. How do I save my photos to my sd card?
    By AC Question in forum Moto G (2013)
    Last Post: 03-07-2016, 06:06 PM
  4. Galaxy S5 email problem, can I get some help?
    By Alexphilly69 in forum Samsung Galaxy S5
    Last Post: 03-07-2016, 05:21 PM
