1. PsychDoc's Avatar
    And if so, does it actually work? I always thought this was a great feature but sadly it never worked at all on the S5 or S6.
    03-04-2016 08:18 PM
  2. 20degrees's Avatar
    My wife's T-Mobile edge has the option. It's late and dark, don't know if it works.
    03-04-2016 08:50 PM
  3. Captpt's Avatar
    It is a very nice feature, my old Note had it and it really did work except as 20degrees stated not under dark conditions.
    03-04-2016 08:56 PM
  4. adelcastillo78's Avatar
    It works on dimmer setting than the GS6. But if the room is completely dark and the light of the screen in white, it will work, once the screen has more dark tones it doesnt work as good.
    03-04-2016 11:04 PM
  5. PsychDoc's Avatar
    That's encouraging because on the S5 and S6 it didn't work at all, regardless of the ambient light level.
    03-05-2016 05:46 AM
  6. inffy's Avatar
    Yes it does have it, but me thinks it's totally useless feature
    03-05-2016 06:03 AM
  7. Gator352's Avatar
    Worked great on my note 4 but never has on my S6. To me, it's hit and miss.
    03-05-2016 06:17 AM
  8. PsychDoc's Avatar
    Yeah, as it's been implemented on the last two flagships it's useless because it doesn't work worth a damn. If it works properly it's an incredibly helpful feature.
    03-05-2016 07:09 AM
  9. Alanhd's Avatar
    I always found smart stay worked ok on my Galaxy S5. I will have to test it on The S7 when I get it.
    03-05-2016 07:35 AM
  1. Replies: 3
    Last Post: 03-06-2016, 01:11 PM
  2. When will we be able to Root the S7?
    By nderic77 in forum Samsung Galaxy S7
    Last Post: 03-05-2016, 12:54 AM
  3. Verizon Galaxy S7 Edge Silver Unboxing, Check that Verizon startup screen.
    By felloffthetruck in forum Samsung Galaxy S7 edge
    Last Post: 03-04-2016, 11:55 PM
  4. Replies: 1
    Last Post: 03-04-2016, 06:23 PM
  5. Replies: 2
    Last Post: 03-04-2016, 05:13 PM
