Would one of you lucky, kind, generous owners of edge 7 test free version of Lightflow to see if it works to control led notifications? I really love that app and won't change phones if it doesn't work. Thanks!
There is a special "Samsung Method" mode in the app. Did you try it? Thanks!I tried it on the S6 and it didn't work properly and caused some problems with the phone as well. Had to uninstall it.
Perhaps someone could try the work-around and explain how it works? Thanks again for your help. It will strongly influence my decision about buying the edgeChatted with the developer. Samsung drivers are apparently even more inconsistent with Marshmallow. I guess the workaround still works. Frustrating.
I am avidly following your reports. I am surprised always on fails to give email notifications! If always on doesn't notify on emails and there is no way to fix Lightflow I just cannot buy this phone. If it isn't too much trouble would you contact Andrew the developer at Reactle (Lightflow). He is a great guy and if you email the issue he may have a special version of Lightflow or may write one just so we can use his app. I thought it might work if the setting to keep the lightflow icon in the pulldown menu were always there. I think I may have read some old version might work. Anyway I really appreciate your reply. I hope you find a solution.I received the phone (S7 Edge) today, tried the paid version of Light Flow (I am a heavy notification user) and it doesn't work. Tried many settings and workarounds (including the Samsung-specific workaround, direct mode, etc.). Nothing.
And the worst problem is that the always-on screen of the S7/Edge only shows missed calls and SMS messages, not all notifications...I am quite stuck at this point. But the phone is very nice, I won't give up just yet
Thanks! Do you have to shut off notifications manually? Can you still use "always on" display?So, I received my S7 edge today. I also had been using the paid version of lightflow recently on my S5 and love it. So, to answer your question, I couldn't get the regular paid version to work. All I would get is a blue notification so I also decided to installed the "legacy version" too like stated above. I had to install it and also keep the paid version installed. I don't know if the legacy works with the regular free version but it definitely is working with the paid version so far. All of the different colored notifications are displaying.
It always did. You have to make app notifications silent and allow lightflow to create sounds. Of course first you must assign sound to each app in lightflow and activate sound within lightflow.FWIW, I installed the Legacy version and it interfered with my sound notifications. I tried a few different work-arounds, but nothing helped.
The sound problem disappeared when I uninstalled Legacy, deleted the leftover folder via File Manager, and restarted the phone.
I'm disappointed because I love Light Flow, but it didn't work for me. I have no idea why it messed with my notification sounds.
