1. RadiantDuck's Avatar
    Hi all! Might be a silly question but it's been many a moon since I've used a phone with capacitive buttons. I know the s7 has a feature to lock the keys during playing games, is there something similar during streaming, like Netflix, YouTube and iplayer etc? Worried that I might accidentally press something while watching.
    03-05-2016 10:20 AM
  2. Carlo Villa's Avatar
    As far as I know for Netflix no. If you press something just go back
    03-05-2016 02:57 PM
  3. recDNA's Avatar
    Is there a way to keep them on all the time
    03-05-2016 03:01 PM
  4. mush10's Avatar
    Yes. Once you get used to location I find just keeping them off is better. I find them distracting.
    03-05-2016 03:02 PM
  5. recDNA's Avatar
    I should have asked HOW do I keep them on all the time. Thanks
    03-05-2016 03:03 PM
  6. Kevin OQuinn's Avatar
    Could you just add Netflix to the gaming launcher to give you the ability to turn off the buttons?
    03-05-2016 03:29 PM
  7. 20degrees's Avatar
    Nope.
    03-05-2016 03:42 PM
  8. Kevin OQuinn's Avatar
    Nope.
    It doesn't let you add Netflix to the folder?
    03-05-2016 03:43 PM
  9. 20degrees's Avatar
    No. Says it needs to request something.
    Kevin OQuinn likes this.
    03-05-2016 03:55 PM
  10. Jelly Belly's Avatar
    Is that so you cannot record off Netflix?
    I was thinking that the build in screen recording is great but not just for games. App reviews would be good.
    What decides what can and canNOT be added?
    03-05-2016 04:05 PM
  11. 20degrees's Avatar
    Root decides! 😀
    03-05-2016 04:41 PM
  12. adelcastillo78's Avatar
    Will pinning the app help you reach your goal?
    03-05-2016 09:38 PM
  13. Rheller82's Avatar
    Search for this in the play store.
    "Touch Lock - Toddler Lock"
    It will lock your buttons. I used it for youtube on note 5 and should work here.
    *edit*
    Oh and when root comes you could do this too.
    www androidexplained com /galaxy-s6-disable-capacitive-buttons/
    03-06-2016 03:29 PM
  1. Home button not working on Android. It's been fine then...
    By Paisley in forum General Help and How To
    Last Post: 06-17-2016, 05:56 PM
  2. can I change the position of my home buttons on turbo 2?
    Last Post: 03-04-2016, 10:18 AM
  3. Recent app button & back button in samsung sm-g355h
    Last Post: 03-04-2016, 04:20 AM
  4. Replies: 2
    Last Post: 03-04-2016, 03:54 AM
  5. home button Home button
    By nonie in forum Samsung Galaxy S5
    Last Post: 03-03-2016, 03:04 PM
