1. mike3000's Avatar
    Hi,
    Not sure if you guys knew, but one of my biggest gripes moving from my note 5 to the S7 Edge was that the S7 Edge only had 4 apps per row on the home screen.
    Well you can change the resolution by pinching the home screen and then selected 5x5 grid.
    Thanks
    03-05-2016 03:51 PM
  2. NexusGirlX's Avatar
    Or you just hold a finger anywhere on a empty area of the screen and you can select the grid from there.
    03-05-2016 04:27 PM
  3. mush10's Avatar
    One of my biggest TouchWiz complaints is that you can't move the app drawer icon. I use Nova for gestures anyway, but cannot understand why they will not let you reposition the icon.
    03-05-2016 04:31 PM
  4. Macklesdaddy's Avatar
    Yes sir, it kills my ocd to not be in the middle
    03-05-2016 05:11 PM
  1. Recent Apps button: Grid view instead of cards?
    By ripcurlksm in forum Samsung Galaxy S6 edge
    Last Post: 09-16-2016, 09:36 AM
  2. How do I remove grid pattern over home screen icons?
    Last Post: 02-28-2016, 07:27 AM
  3. Replies: 9
    Last Post: 01-28-2016, 02:41 PM
  4. how to get grid view menu in solo launcher
    Last Post: 01-20-2016, 02:03 AM
  5. Replies: 1
    Last Post: 01-09-2016, 10:34 AM
