03-18-2016 01:10 PM
31 12
tools
  1. Nadeem Memon's Avatar
    Plz send image of any app having white backgound between note 5 and s7 edge thanks
    03-16-2016 04:37 AM
  2. Nadeem Memon's Avatar
    It is not duller, samsung in android 6.0 has changed the dialer color scheme
    03-16-2016 04:42 AM
  3. mush10's Avatar
    I've only had my Note 5 for a month so I haven't noticed any lag. I just can't get the battery to give me more then two hours screen time in a day. Earlier, it lost 10% in two hours of just sitting there after taking it off the charger.
    Go to application manager and uninstall updates for both Google Play services and the Google app. Then reinstall them when prompted. That should stop your battery drain while idle.
    Dukins likes this.
    03-16-2016 05:04 AM
  4. Dm1120's Avatar
    So i'm in same boat. have my Note 5 and pre order s7edge but i'm afraid that the camera will be huge letdown,as at XDA forums there are conflict reports about quality.
    Anyone that went S7 Edge how is the camera?
    Absolutely insane camera in low light conditions. Pictures that I took in low light on my Note 5 look amazing when taken on the S7 Edge. For me that alone makes the camera better.
    03-16-2016 06:21 AM
  5. Dukins's Avatar
    Ill try this as well. Thanks for the tip. Because I am very frustrated ready to go over the "edge" lol. Seriously I want to toss this phone out of my car window and watch it slide several times. The battery is ridiculous for me on this phone. Im still going to call Verizon and get a replacement and i'll check the idle drain until I receive my new phone. My edge is functioning like her Note 5.
    03-16-2016 06:45 AM
  6. FutureMech's Avatar
    True i went to same places and made same shots, there is a LOT of difference, Note 5 photos are fine but S7E just wipe the floor with it, everything is so clear the detail and colour accuracy is PEFECT, despite 12MP when zoomed i can see more detail on S7E.
    03-18-2016 01:10 PM
31 12
  1. Replies: 1
    Last Post: 03-08-2016, 09:10 AM
  2. How can I tell if Doze is working on my Samsung Galaxy S7 Edge?
    By janderson1271 in forum Samsung Galaxy S7 edge
    Last Post: 03-08-2016, 07:21 AM
  3. Galaxy S5 email problem, can I get some help?
    By Alexphilly69 in forum Samsung Galaxy S5
    Last Post: 03-07-2016, 05:21 PM
