1. pshows's Avatar
    I was able to move a couple of apps to my SD card, now whenever I try to move apps it gives me a screen like it's going to move it but with a black bar at the bottom and nothing happens. Has by one had this issue and if so how did you fix this?
    03-06-2016 04:29 AM
  2. rkkeller's Avatar
    Press or slide the blank black bar. The screen will change.
    03-06-2016 09:49 AM
  3. pshows's Avatar
    Did not work it's just a solid black bar
    03-06-2016 12:21 PM
  4. pshows's Avatar
    Please see screen shot below
    03-06-2016 12:26 PM
  5. pshows's Avatar
    03-06-2016 12:26 PM
  6. reyno626's Avatar
    I ran into the same problem. I haven't resolved it yet. Don't know if it matters, but I'm using a 200GB Sandisk microSD card.
    03-06-2016 06:58 PM
  7. pshows's Avatar
    I'm using 64gb
    03-06-2016 07:07 PM
  8. wxman2003's Avatar
    Move the last app you added to the sd card back to the phone. Maybe that app hosed it up. Then try moving other apps instead.
    03-06-2016 07:30 PM
  9. Darren Pearce1's Avatar
    Hi
    bn on old bnp
    p
    03-07-2016 11:38 PM
  10. airkorea08's Avatar
    I saw a video today that shows that you just need to click on the right side of the black bar and it will continue to move the app to the SD card
    pshows likes this.
    03-08-2016 12:59 AM
  11. pshows's Avatar
    Thanks!
    03-08-2016 01:01 AM
  12. Chrisu24's Avatar
    I cannot move any apps!!! It doesnt even show me the option at all. In none of the apps in application manager. Is it disabled on At&T S7 Edge phones?
    What can I do?
    03-10-2016 02:27 AM
  13. KimJongOMG's Avatar
    What can I do?
    Not all apps can be moved. I was only able to move about half my apps over. What apps are you trying to move over? System apps and quite a few non-system apps can't be moved sadly.
    03-10-2016 02:30 AM
  14. Chrisu24's Avatar
    That is what I am saying. I cannot move ANY app. Maybe it has something to do with the At&T version?
    It only says Media and Photos can be saved on the sd card.
    Am I the only one with that problem?
    03-10-2016 12:26 PM
  15. lancashirehotpot's Avatar
    I can move apps to the SD card just they lag a little when I do. Does anyone know how to get it to automatically save photos from the Web to the SD card rather than on the device? If I take photos then they go to SD but not if I save them
    03-10-2016 12:34 PM
  16. DJBeanPole's Avatar
    Hi
    bn on old bnp
    p
    This is by far the best method for solving this problem.
    03-10-2016 12:54 PM
  17. billyjoebob007's Avatar
    SOoooo, what tha ? Phone is useless if we can not move apps to sd card ! I found these instructions for doing it:
    * With a microSD card installed, launch the Settings app.
    * Find and select Storage from the list of options.
    * Tap on Internal storage.
    * Select Apps.
    * Locate the app you'd like to move, and tap on it.
    * Under the "Storage Used" section, tap on the Change button and select SD Card.
    BUt in mine i dont have the "Select Apps" option listed.
    I have tried ap manager pro 3 and app2sd & app manager save space , i get message from app like " the device does not have a real primary external storage,or the primary storage is emulated. moving app to sd function can not be supported by this device."
    If no fix by wed im returning it ! BS.
    03-13-2016 04:23 PM
  18. billyjoebob007's Avatar
    *duplicate post removed*
    03-13-2016 04:25 PM
  19. InVez's Avatar
    For those Who can move apps to sd card : restart phone and data will be shown on sd card
    03-13-2016 06:00 PM
  20. cleb77's Avatar
    Hi
    bn on old bnp
    p
    Hi,
    Im from Brazil! I can't understand it
    bn on old bnp.. it's like btn + hold btn pwr?
    sorry my bad english and lack Knowledge
    04-22-2016 03:59 PM
  21. Shoesmom's Avatar
    Can anyone tell me if you move an app to the sd card, does it stay on the sd card after an update or does it get moved back to the internal storage like on my s5?
    05-25-2016 09:03 PM
  22. afh3's Avatar
    The latter.
    Sucks that there is no quick way to discern which ones are, and are not, moved. On my Tab S (running 5.0.2) there is a convenient check-box that shows the application's current status in that respect.
    On my (VZW) S7 Edge, I can find no way of confirming this without inspecting each item.
    05-26-2016 08:38 AM
  1. Anyone having issue with Chromecast?
    By mxmarcus in forum Google Chromecast
    Last Post: 03-08-2016, 09:46 AM
  2. How can I tell if Doze is working on my Samsung Galaxy S7 Edge?
    By janderson1271 in forum Samsung Galaxy S7 edge
    Last Post: 03-08-2016, 08:21 AM
  3. Replies: 1
    Last Post: 03-07-2016, 07:10 PM
  4. How do I save my photos to my sd card?
    By AC Question in forum Moto G (2013)
    Last Post: 03-07-2016, 07:06 PM
